I use ESP-IDF v 3.1.2
devbord - ESP32-PICO-KIT.
I try to realize wi-fi sniffer, send via UART captured 802.11 frame. Also in asynchronous mode receive settings from PC.
So, this code is initialize UART
uart_config_t uart_cfg = {
.baud_rate = UART_2_PC_BAUD_RATE,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
ESP_ERROR_CHECK(uart_param_config(UART_2_PC, &uart_cfg));
ESP_ERROR_CHECK(uart_set_pin(UART_2_PC, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
ESP_ERROR_CHECK(uart_driver_install(UART_2_PC, 4096, 4096, 0, NULL, 0));Code: Select all
xReturned = xTaskCreatePinnedToCore(vUartWiFi, "UartWiFi", 8192, NULL, 1, NULL, 1);
if (xReturned != pdPASS)
printf("Can't create UartWifi task\n");
printf("ESP32 will be reset after 3 sec\n");
vTaskDelay(3000/ portTICK_PERIOD_MS);
esp_restart();
xReturned = xTaskCreatePinnedToCore(vUartSettings, "UartSettings", 4096, NULL, 12, NULL, 1);
printf("Can't create UartSettings task\n");
esp_restart();
}receive 802.11 frame from callback, analyze this frame and send via uart. I use
uart_write_bytes(UART_2_PC, (char*) pkt, wifi_frame.ESP32_RADIO_METADATA.sig_len);the main idea of task "UartSettings"
receive settings (set/get channel WiFi, enable/disable promiscuous mode etc) from PC
void vUartSettings(void *pvParameters)
uint8_t tlv_cmd[CMD_TLV_BUFFER];
// tlv_cmd_t tlv_cmd;
size_t len_tlv_cmd =0;
int rx_bytes;
uint8_t current_wifi_channel;
while(1)
uart_get_buffered_data_len(UART_2_PC, &len_tlv_cmd);
// printf("\n*******\n");
// printf("Rx bytes = %d\n", len_tlv_cmd);
// printf("*******\n");
if (len_tlv_cmd > 0)
rx_bytes = uart_read_bytes(UART_2_PC, tlv_cmd, len_tlv_cmd, 10000/portTICK_RATE_MS);
if (rx_bytes > 0)
switch(tlv_cmd[0])
case 1:
printf("start/stop sniffer\n");
esp_wifi_set_promiscuous(true);
break;
default:
printf("\n*******\nUnknown cmd\n*****\n");
vTaskDelete(NULL);
}Every time "uart_read_bytes" executed -> promiscuous mode if OFF.
What could be wrong?
Thank you.
P.S.
Full code avaible here
