[SOLVED] INTERRUPT UART example work only one time and after hold
gpezzella
Postby gpezzella » Mon Apr 01, 2019 11:51 am
Hello
I'm testing your ISR UART code and it work but ONLY ONE TIME!
After it hold and not receive nothing. Why??
Next question:
How save in string variable received data??
String Received_Data = ??? (dtmp)
Please reply me soon.
Thanks in advice
Code: Untitled.cpp Select all
* https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/peripherals/uart.html#uart-api-setting-communication-pins
#include "driver/uart.h"
#define NUMERO_PORTA_SERIALE UART_NUM_2
#define BUF_SIZE (1024 * 2)
#define RD_BUF_SIZE (1024)
static QueueHandle_t uart2_queue;
static const char * TAG = "";
#define U2RXD 33
#define U2TXD 32
void setup() {
Serial.begin(115200);
//Configuro la porta Serial2 (tutti i parametri hanno anche un get per effettuare controlli)
uart_config_t Configurazione_UART2 = {
.baud_rate = 9600,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(NUMERO_PORTA_SERIALE, &Configurazione_UART2);
//Firma: void esp_log_level_set(const char *tag, esp_log_level_tlevel)
esp_log_level_set(TAG, ESP_LOG_INFO);
//Firma: esp_err_tuart_set_pin(uart_port_tuart_num, int tx_io_num, int rx_io_num, int rts_io_num, int cts_io_num)
uart_set_pin(NUMERO_PORTA_SERIALE, U2TXD, U2RXD, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
//Firma: uart_driver_install(UART_NUM_2, uart_buffer_size, uart_buffer_size, 10, &uart_queue, 0));
// uart_driver_install(Numero_porta, RXD_BUFFER, TXD_Buffer, event queue handle and size, flags to allocate an interrupt)
uart_driver_install(NUMERO_PORTA_SERIALE, BUF_SIZE, BUF_SIZE, 20, &uart2_queue, 0);
//Create a task to handler UART event from ISR
xTaskCreate(UART_ISR_ROUTINE, "UART_ISR_ROUTINE", 2048, NULL, 12, NULL);
void loop() {
Serial.println("Waiting data from SERIAL 2....");
delay(1000);
static void UART_ISR_ROUTINE(void *pvParameters){
uart_event_t event;
size_t buffered_size;
uint8_t* dtmp = (uint8_t*) malloc(RD_BUF_SIZE);
Serial.println("INSIDE ISR");
if(xQueueReceive(uart2_queue, (void * )&event, (portTickType)portMAX_DELAY)) {
bzero(dtmp, RD_BUF_SIZE);
ESP_LOGI(TAG, "uart[%d] event:", EX_UART_NUM);
if (event.type==UART_DATA){
//ESP_LOGI(TAG, "[UART DATA]: %d", event.size);
uart_read_bytes(NUMERO_PORTA_SERIALE, dtmp, event.size, portMAX_DELAY);
Serial.println("DATA= ");
//ESP_LOGI(TAG, "[DATA EVT]:");
//uart_write_bytes(NUMERO_PORTA_SERIALE, (const char*) dtmp, event.size);
}// if event.type
}//if xQuequeReceive
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
gpezzella
Re: INTERRUPT UART example work only one time and after hold
Postby gpezzella » Mon Apr 01, 2019 2:18 pm
update 1:
I have change the code inside UART_ISR_ROUTINE in this way and it return me:
ISR Status= 0
RX FIFO LEN=0
Why?
uart_event_t event;
uint16_t rx_fifo_len=0, ISR_Status=0, i=0;
ISR_Status = UART2.int_st.val; // read UART interrupt Status
Serial.print("ISR Status= ");Serial.println(ISR_Status);
rx_fifo_len = UART2.status.rxfifo_cnt; // read number of bytes in UART buffer
Serial.print("RX FIFO LEN= ");Serial.println(rx_fifo_len);
while(rx_fifo_len){
rxbuf[i++] = UART2.fifo.rw_byte; // read all bytes
Serial.print(rxbuf[i++]);
rx_fifo_len--;
// after reading bytes from buffer clear UART interrupt status
uart_clear_intr_status(NUMERO_PORTA_SERIALE, UART_RXFIFO_FULL_INT_CLR|UART_RXFIFO_TOUT_INT_CLR);
}// if event.type
vTaskDelete(NULL);
Dazza0
Postby Dazza0 » Mon Apr 01, 2019 3:36 pm
Because you're creating a Task instead of an ISR? The task simply receives form the queue once, then deletes itself.
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
If you are implementing a task to continuously receive from a UART event queue, it should be implemented as some form of loop
gpezzella
Postby gpezzella » Mon Apr 01, 2019 3:46 pm
Hi ESP_dazz
could you gently show me the correct way?
I'm new with ESP32 and for this reason I reuse code of example without understand every line of code.
In any case with update 1 code my output is:
ISR_Status=0
rx_fifo_len=0
Thanks in advice
Dazza0
Postby Dazza0 » Mon Apr 01, 2019 4:15 pm
A FreeRTOS task should be implemented as an infinite loop.
Code: task_example.cpp Select all
uart_event_t event;
bool exit_condition = false;
//Infinite loop to run main bulk of task
while (1) {
//Loop will continually block (i.e. wait) on event messages from the event queue
//Handle received event
if (event.type == UART_DATA) {
//Handle your uart reading here
else if (event.type == UART_FRAME_ERR) {
//Handle frame error event
... //Keep adding else if statements for each UART event you want to support
else {
//Final else statement to act as a default case
//If you want to break out of the loop due to certain conditions, set exit condition to true
if (exit_condition) {
break;
//Out side of loop now. Task needs to clean up and self terminate before returning
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
As to why the ISR_Status=0 and rx_fifo_len=0, it could be because you are receive different events other than UART_DATA, so I suggest you check for the type of event that you are receiving.
EDIT: Didn't see you checked for ISR_Status=0 and rx_fifo_len=0 after checking UART_DATA. Are you trying to use the Arduino UART driver or the ESP-IDF UART driver?
gpezzella
Postby gpezzella » Mon Apr 01, 2019 4:31 pm
Hi ESP_Dazz
now it work in continuous mode!!
I use Arduino for UART0 (debug) and idf for UART2
I replace Serial.print("DATA= ") with follow code but cannot read nothing...why?
Serial.print("DATA= ");
while(rx_fifo_len){
Serial.print(rxbuf[i]);
rx_fifo_len--;
Dazza0
Postby Dazza0 » Mon Apr 01, 2019 4:46 pm
Well I'm not exactly sure why you are checking the values of hardware registers (i.e. UART2.status.rxfifo_cnt). The driver should already handle the transfer of data from the hardware FIFO to a software ring buffer. I suggest you take a look at the existing UART examples on how to use the IDF UART driver API properly.
gpezzella
Postby gpezzella » Tue Apr 02, 2019 10:14 am
FINAL WORKING PROGRAM
IT READ DATA FROM UART2 IN INTERRUPT MODE AND SEND TO UART0:
#define U2RXD 33
#define U2TXD 32
uint8_t rxbuf[256]; //Buffer di ricezione
uint16_t rx_fifo_len; //Lunghezza dati
void setup() {
.baud_rate = 9600,
void loop() {
delay(1000);
uart_event_t event;
while (1) {
uint8_t UART2_data[128];
int UART2_data_length = 0;
ESP_ERROR_CHECK(uart_get_buffered_data_len(UART_NUM_2, (size_t*)&UART2_data_length));
UART2_data_length = uart_read_bytes(UART_NUM_2, UART2_data, UART2_data_length, 100);
Serial.println("LEN= ");Serial.println(UART2_data_length);
for(byte i=0; i<UART2_data_length;i++) Serial.print((char)UART2_data[i]);
Serial.println("");
//TODO...
//else if (event.type == OTHER EVENT) {
//TODO...
else {
//TODO...
break;
vTaskDelete(NULL);
IOTCure
Re: [SOLVED] INTERRUPT UART example work only one time and after hold
Postby IOTCure » Wed Sep 11, 2019 1:04 pm
Hello gpezella,
I tried to run your code, it compiles successfully but UART2 is not working working in Interrupt mode for RX.
when I tried to debug with serial monitor, I found the provided ISR function static void UART_ISR_ROUTINE(void *pvParameters) is executed only one time at start rest never call again in program.
i tried to send data on UART2 and looking for same data on UART0, but it is not working.
kindly help, what i am missing here.
Thanks In Advance.
Regards,
Cure
JJ_Bras
Postby JJ_Bras » Wed Dec 01, 2021 1:34 pm
Hi everyone, I am with the same problem. I think that it is stoped into "xQueueReceive(uart2_queue, (void * )&event, (portTickType)portMAX_DELAY)"
Users browsing this forum: Google [Bot], Qwantbot and 2 guests
