How can I completely reset Wi-Fi and turn it on again?
Glebiys
Postby Glebiys » Sun Apr 07, 2019 4:50 pm
Hi!
I need to control the stability of the Wifi connection and reset the Wifi driver mode in case of problems with reconnection.
In the documentation, I found a way to completely stop Wifi:
esp_wifi_disconnect ();
esp_wifi_stop ();
esp_wifi_deinit ();
This should completely disable Wifi and clear its configuration.
After that, I have to start the Wifi connection again. What sequence of commands can I do this?
And in general, how correct is this decision? Does it harm the ESP? If so, how can I do this correctly? My goal is high resiliency Wifi connectivity and reliable automatic reconnection in case of failure.
Users browsing this forum: Applebot, Semrush [Bot], YisouSpider and 1 guest
