Esp not connecting to wifi after some days
fly135
Re: Esp not connecting to wifi after some days
Postby fly135 » Fri May 31, 2019 4:15 pm
Hello everyone,
I am getting wifi disconnect issue from very long time.
As I kept my ESP32 live for long time, it disconnects and not getting connected to the configured SSID and PASSWORD again till switch it OFF and ON again. I am using esp-idf v3.1.3.
Please help me to resolve this issue.
Thanks in advance.
Why not just reboot when it fails after xxx retries? The ESP32 boots so quickly that it shouldn't be too much of an issue.
John A
burkulesomesh43
Postby burkulesomesh43 » Mon Jun 03, 2019 5:42 am
Hello everyone,
Thanks in advance.
John A
I am using esp this way already. I am confused that its a hardware issue or esp idf. or it may be not issue from esp side overall.
I have collected some logs. can u please check it and let me know if you get some from that.
Please see following code for your reference.
DCR: Disconnect Reason
MAC: MAC Address of connected AP
CH: Channel
LIP: Lost IP
TM: Time and Date
Code: Untitled.txt Select all
DCR:201,TM:
DCR:201,TM:
MAC:80:8D:B7:7F:D7:A1,CH:1/0,rssi:-52,TM:
DCR:201,TM:
DCR:2,TM:
DCR:4,TM:
DCR:201,TM:
DHCP:0,TM:
MAC:48:4A:E9:CD:C4:01,CH:6/0,rssi:-63,TM:
DCR:200,TM:23-05-2019 17:50:53
DCR:201,TM:23-05-2019 17:50:59
MAC:48:4A:E9:CD:C5:C1,CH:1/0,rssi:-59,TM:23-05-2019 17:51:17
DCR:6,TM:24-05-2019 10:18:32
DCR:201,TM:24-05-2019 10:18:39
MAC:48:4A:E9:CD:C4:01,CH:6/0,rssi:-61,TM:24-05-2019 10:18:57
DCR:200,TM:24-05-2019 10:21:36
DCR:201,TM:24-05-2019 10:21:43
MAC:48:4A:E9:CD:C5:C1,CH:1/0,rssi:-58,TM:24-05-2019 10:22:00
DCR:200,TM:24-05-2019 16:48:23
DCR:201,TM:24-05-2019 16:48:29
DCR:203,TM:24-05-2019 16:48:49
DCR:2,TM:24-05-2019 16:48:51
DCR:201,TM:24-05-2019 16:48:53
DCR:4,TM:24-05-2019 16:48:55
LIP,TM:24-05-2019 16:50:23
DCR:201,TM:
DCR:201,TM:
DHCP:0,TM:
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-58,TM:
DCR:8,TM:24-05-2019 17:44:24
DCR:201,TM:24-05-2019 17:44:31
MAC:48:4A:E9:CD:C4:01,CH:6/0,rssi:-63,TM:24-05-2019 17:44:50
DCR:8,TM:24-05-2019 17:44:54
DCR:201,TM:24-05-2019 17:45:00
DCR:203,TM:24-05-2019 17:45:19
DCR:201,TM:24-05-2019 17:45:21
DCR:203,TM:24-05-2019 17:45:22
MAC:48:4A:E9:CD:C4:01,CH:6/0,rssi:-63,TM:24-05-2019 17:45:23
DCR:8,TM:24-05-2019 17:45:27
DCR:201,TM:24-05-2019 17:45:34
DCR:204,TM:24-05-2019 17:46:03
DCR:201,TM:24-05-2019 17:46:05
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-57,TM:24-05-2019 17:46:06
DCR:8,TM:24-05-2019 17:46:13
DCR:201,TM:24-05-2019 17:46:20
LIP,TM:24-05-2019 17:46:24
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:46:39
DCR:8,TM:24-05-2019 17:46:40
DCR:201,TM:24-05-2019 17:46:46
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:47:05
DCR:8,TM:24-05-2019 17:47:10
DCR:201,TM:24-05-2019 17:47:16
DCR:204,TM:24-05-2019 17:47:44
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:47:47
DCR:8,TM:24-05-2019 17:47:48
DCR:201,TM:24-05-2019 17:47:54
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-55,TM:24-05-2019 17:48:13
DCR:8,TM:24-05-2019 17:48:15
DCR:201,TM:24-05-2019 17:48:21
LIP,TM:24-05-2019 17:48:40
DCR:2,TM:24-05-2019 17:48:41
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-57,TM:24-05-2019 17:48:43
DCR:8,TM:24-05-2019 17:48:44
DCR:201,TM:24-05-2019 17:48:50
DCR:4,TM:24-05-2019 17:49:10
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-57,TM:24-05-2019 17:49:12
DCR:8,TM:24-05-2019 17:49:13
DCR:201,TM:24-05-2019 17:49:20
DCR:204,TM:24-05-2019 17:49:48
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-57,TM:24-05-2019 17:49:50
DCR:8,TM:24-05-2019 17:49:51
DCR:201,TM:24-05-2019 17:49:58
DCR:203,TM:24-05-2019 17:50:16
MAC:48:4A:E9:CD:C4:01,CH:6/0,rssi:-62,TM:24-05-2019 17:50:18
DCR:200,TM:24-05-2019 17:50:51
DCR:201,TM:24-05-2019 17:50:58
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:51:17
DCR:8,TM:24-05-2019 17:51:18
DCR:201,TM:24-05-2019 17:51:25
DCR:2,TM:24-05-2019 17:51:44
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:51:46
DCR:8,TM:24-05-2019 17:51:47
DCR:201,TM:24-05-2019 17:51:54
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:52:13
DCR:8,TM:24-05-2019 17:52:14
DCR:201,TM:24-05-2019 17:52:21
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:52:40
DCR:8,TM:24-05-2019 17:52:41
DCR:201,TM:24-05-2019 17:52:48
LIP,TM:24-05-2019 17:52:51
DCR:2,TM:24-05-2019 17:53:07
DCR:201,TM:24-05-2019 17:53:10
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-57,TM:24-05-2019 17:53:10
DCR:8,TM:24-05-2019 17:53:12
DCR:201,TM:24-05-2019 17:53:18
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:53:38
DCR:8,TM:24-05-2019 17:53:39
DCR:201,TM:24-05-2019 17:53:46
MAC:48:4A:E9:CD:C5:C1,CH:11/0,rssi:-56,TM:24-05-2019 17:54:05
//At this point, device is get stable as we restarted it after 10 minutes of wifi disconnect(from TM:24-05-2019 17:44:24).
Somesh Burkule
burkulesomesh43
Postby burkulesomesh43 » Mon Jun 03, 2019 1:10 pm
So this wifi issue is idf related issue. I am using esp-idf v3.2. is it fixed in it?
Somesh Burkule
WiFive
Postby WiFive » Mon Jun 03, 2019 3:26 pm
It has not been released for 3.2 but you should either request a patched version on that GitHub issue or try the master version. It might or might not be related to your problem.
