Pressure Sensor
Jeroem
Pressure Sensor
Postby Jeroem » Thu Jun 06, 2019 3:07 pm
Hello Everyone,
I am using a pressure sensor like this:"
https://www.banggood.com/200PSI-Pressur ... 20789.html
I followed this youtube guide: https://www.youtube.com/watch?v=AB7zgnfkEi4
The mcu I am using is a ESP32. The sensors gets 4.75volt power and the ESP32 gets 3.3v
The sensors read out fine but the results are very unstable.
Analog value - voltage - pascal - bar:
384 - 0.47 - -3750.00 - -0.00
362 - 0.44 - -84316.41 - -0.08
400 - 0.49 - 54843.75 - 0.05
396 - 0.48 - 40195.31 - 0.04
368 - 0.45 - -62343.75 - -0.06
416 - 0.51 - 113437.50 - 0.11
352 - 0.43 - -120937.50 - -0.12
376 - 0.46 - -33046.87 - -0.03
480 - 0.59 - 347812.50 - 0.35
361 - 0.44 - -87978.52 - -0.09
365 - 0.45 - -73330.08 - -0.07
This is in my room, so 0.47 voltage seems to be the best result, 0.00.
But when I blow in the pressure sensor the voltage goes up and so does the bar.
I don't know what I do wrong but would like to fix the unstable results.
Does anyone have an idea what could go wrong?
This is the code:
float getSensorvalue(int analoge){
  int sensorVal=analogRead(analoge);
  Serial.print(sensorVal);Serial.print(" - ");
  float voltage = (sensorVal*5.0)/4096.0;
  Serial.print(voltage);Serial.print(" - ");
  float pressure_pascal = (3.0*((float)voltage-0.47))*1000000.0;
  Serial.print(pressure_pascal);Serial.print(" - ");
  float pressure_bar = pressure_pascal/10e5;
  Serial.println(pressure_bar);
  delay(100);
  return pressure_bar;
void loop(){
	getSensorvalue(34);
	getSensorvalue(35);
	getSensorvalue(32);
	delay(1000);
Thanks everyone.
portasynthinca3
Re: Pressure Sensor
Postby portasynthinca3 » Thu Jun 06, 2019 3:34 pm
I think the reason with the unstable value is the ADC noise. To overcome this, you can use multisampling. Instead of doing calculations on one value, use an average of several ADC readings, or even better, use a low-pass filter. Here's a code for the simple averaging:
int adc_value_final = 0;
int adc_samples = 64;
for(int i = 0; i < adc_samples; i++){
  adc_value_final += analogRead(analog_pin);
adc_value_final /= adc_samples;
//...and do pressure calculations using adc_value_final variable instead of analogRead()
salvim
Re: Pressure Sensor
Postby salvim » Mon Jul 13, 2020 1:59 am
Hello Jeroem, how are you? Have you made any progress in using this pressure sensor?
Users browsing this forum: Bing [Bot], ChatGPT-User, coccocbot and 3 guests
