"Mwifi also supports the way to fix the root node" What does this mean?
eos1d3
Postby eos1d3 » Sun Jul 14, 2019 6:22 am
In Mwifi API, https://docs.espressif.com/projects/esp ... index.html
Mwifi also supports the way to fix the root node. In this case, the nodes in the entire ESP-MESH network cannot communicate with the external IP network through wifi.
What does this mean? What is "FIX"?
LBB
Re: "Mwifi also supports the way to fix the root node" What does this mean?
Postby LBB » Mon Jul 15, 2019 6:27 am
Hi eos1d3,
It means when the devices is powered on, it can only be root node. As this root don't connect to a router, then the whole network under this root won't be able to communicate with the external IP network.
eos1d3
Postby eos1d3 » Tue Jul 16, 2019 3:48 pm
So it is "no_router" mode in the examples, right? But I think the wording is confusing.
Thanks!
LBB
Postby LBB » Wed Jul 17, 2019 4:22 am
Yes, it works in no_router situation, but even if there is router, this kind of networking still works.
In some special scenario, we may need some devices (audio devices with WROVER module for example) to be root node as it has more powerful computing capacity, to control other nodes(bulbs with ESP32-S0WD chip), then in this system we may need the smart speaker to become the root.
