Esp 32 is running on STA-AP wifi mode, I change wifi ssid and password to something which is not available ,which disconnects the ESP-32 from station. Now when I restart the module,station is disconnected at the same time access point doesn't show up in my mobile wifi list and if it shows up, doesn't connect with it.
Could u please tell where is the problem here??
Ritu
Problem in Access Point Mode
Re: Problem in Access Point Mode
Check if the password has at least 8 characters and try to avoid special symbols. Give some code so we can resolve it.
There was a special character in passphrase and of 8 characters. Attached is the file for wifi configuration.
- wifi.c
- (6.54 KiB) Downloaded 907 times
Hello,There was a special character in passphrase and of 8 characters. Attached is the file for wifi configuration.
Which ESP32 IDF you are using? Can you please try AP with open environment?
Because we are using AP+STA mode without any issue in connection and disconnection state like you have mentioned.
Regards,
Ritesh Prajapati
Ritesh Prajapati
This is my ESP-IDF version v4.0-dev-217-g5b2247df2.
I added a little delay when Sta Disconnection event is received and so far we are not facing any issue.
Ritu
Ritu
Great. Thanks for update regarding same.Hello,
Ritu
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Semrush [Bot] and 10 guests
