ESP32 BLE one client connect to multiple BLE servers
eccmaster
Postby eccmaster » Wed Jul 31, 2019 10:58 pm
Hi
I would like to use an ESP32 to connect to 3 BLE LED controllers. They all have unique addresses, but have the same name "hzt" and they use the same Service and Characteristic UUID. I currently am able to connect to each one individually and turn the lights on and off. But I would like to connect to all of them at the same time and turn them all on at the same time and off at the same time. All the controllers are in the same room. How do I connect to them all at the same time
Thank you
chegewara
Re: ESP32 BLE one client connect to multiple BLE servers
Postby chegewara » Sun Aug 11, 2019 12:31 am
This is old code (almost year now), but i think it may be what you are looking for:
 * Create a sample BLE client that connects to a BLE server and then retrieves the current
 * characteristic value.  It will then periodically update the value of the characteristic on the
 * remote server with the current time since boot.
//#include <esp_log.h>
#include <string>
#include <sstream>
#include <sys/time.h>
#include "BLEDevice.h"
//#include "BLEAdvertisedDevice.h"
//#include "BLEClient.h"
//#include "BLEScan.h"
//#include "BLEUtils.h"
#include "Task.h"
//#include "sdkconfig.h"
static const char* LOG_TAG = "SampleClient";
BLEScan *pBLEScan;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
// The remote service we wish to connect to.
static BLEUUID serviceUUID("4fafc201-1fb5-459e-8fcc-c5c9c331914b");
// The characteristic of the remote service we are interested in.
static BLEUUID    charUUID("beb5483e-36e1-4688-b7f5-ea07361b26a8");
void read_task(void* data){
  BLERemoteCharacteristic* pBLERemoteCharacteristic = (BLERemoteCharacteristic*)data;
  ESP_LOGI(LOG_TAG, "%s", pBLERemoteCharacteristic->readValue().c_str());
  vTaskDelete(NULL);
void scan(void*);
class MyCallbacks : public BLEClientCallbacks {
  void onConnect(BLEClient* pC){
  void onDisconnect(BLEClient* pC) {
    xTaskCreate(scan, "scan", 4048, NULL, 6, NULL);
static void notifyCallback(
  BLERemoteCharacteristic* pBLERemoteCharacteristic,
  uint8_t* pData,
  size_t length,
  bool isNotify) {
    ESP_LOGE(LOG_TAG, "Notify callback for characteristic %s of data %s length %d",
        pBLERemoteCharacteristic->getUUID().toString().c_str(), ((char*) pData), length);
 * Become a BLE client to a remote BLE server.  We are passed in the address of the BLE server
 * as the input parameter when the task is created.
class MyClient: public Task {
  void run(void* data) {
    ESP_LOGI(LOG_TAG, "5--> %d", uxTaskGetStackHighWaterMark(NULL));
    BLEAddress* pAddress = (BLEAddress*)data;
    BLEClient*  pClient  = BLEDevice::createClient();
    BLEDevice::setMTU(100);
    pClient->setClientCallbacks(new MyCallbacks());
    // Connect to the remove BLE Server.
    pClient->connect(*pAddress);
    BLERemoteService* pRemoteService;
    BLERemoteCharacteristic* pRemoteCharacteristic;
    ESP_LOGI(LOG_TAG, "6--> %d", uxTaskGetStackHighWaterMark(NULL));
    // Obtain a reference to the service we are after in the remote BLE server.
    pRemoteService = pClient->getService(serviceUUID);
    if (pRemoteService == nullptr) {
      ESP_LOGD(LOG_TAG, "Failed to find our service UUID: %s", serviceUUID.toString().c_str());
      return;
  ESP_LOGI(LOG_TAG, "7--> %d", uxTaskGetStackHighWaterMark(NULL));
    // Obtain a reference to the characteristic in the service of the remote BLE server.
    pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
    if (pRemoteCharacteristic == nullptr) {
      ESP_LOGD(LOG_TAG, "Failed to find our characteristic UUID: %s", charUUID.toString().c_str());
      return;
    pRemoteCharacteristic->registerForNotify(notifyCallback);
    while(pClient->isConnected()) {
      // Set a new value of the characteristic
  ESP_LOGI(LOG_TAG, "8--> %d", uxTaskGetStackHighWaterMark(NULL));
      ESP_LOGD(LOG_TAG, "Setting the new value");
      std::ostringstream stringStream;
      struct timeval tv;
      gettimeofday(&tv, nullptr);
      stringStream << "Time since boot com 12: " << tv.tv_sec << "." << tv.tv_usec;
      pRemoteCharacteristic->writeValue(stringStream.str(), false);
      FreeRTOS::sleep(3000);
    ESP_LOGD(LOG_TAG, "%s", pClient->toString().c_str());
    ESP_LOGD(LOG_TAG, "-- End of task");
    stop();
  } // run
}; // MyClient
void scan(void*){
  BLEScanResults results =  pBLEScan->start(3);
ESP_LOGE(LOG_TAG, "coun %d", results.getCount());
  for(int i=0;i<results.getCount();i++) {
    auto res = results.getDevice(i);
    MyClient* pMyClient = new MyClient();
    pMyClient->setStackSize(18000);
    pMyClient->start(new BLEAddress(*res.getAddress().getNative()));
    vTaskDelay(100);
  vTaskDelete(NULL);
 * Scan for BLE servers and find the first one that advertises the service we are looking for.
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
   * Called for each advertising BLE server.
  void onResult(BLEAdvertisedDevice advertisedDevice) {
    ESP_LOGD(LOG_TAG, "Advertised Device: %s", advertisedDevice.toString().c_str());
  ESP_LOGI(LOG_TAG, "3--> %d", uxTaskGetStackHighWaterMark(NULL));
      ESP_LOGD(LOG_TAG, "Found our device!  address: %s", advertisedDevice.getAddress().toString().c_str());
      pMyClient->setStackSize(8000);
      pMyClient->start(new BLEAddress(*advertisedDevice.getAddress().getNative()));
  ESP_LOGI(LOG_TAG, "4--> %d", uxTaskGetStackHighWaterMark(NULL));
    // } // Found our server
  } // onResult
}; // MyAdvertisedDeviceCallbacks
 * Perform the work of a sample BLE client.
void SampleClient(void*) {
  // ESP_LOGD(LOG_TAG, "Scanning sample starting");
  esp_log_level_set("*", ESP_LOG_INFO);
  BLEDevice::init("esp32");
  pBLEScan = BLEDevice::getScan();
  // pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks(), false);
  pBLEScan->setActiveScan(true);
  pBLEScan->setInterval(189);
  pBLEScan->setWindow(29);
  ESP_LOGI(LOG_TAG, "1--> %d", uxTaskGetStackHighWaterMark(NULL));
    pMyClient->setStackSize(5000);
    vTaskDelay(100);
  ESP_LOGI(LOG_TAG, "2--> %d", uxTaskGetStackHighWaterMark(NULL));
  while(1){
  delay(1000);
} // SampleClient
void setup() {
  Serial.begin(115200);
  Serial.println("Starting Arduino BLE Client application...");
  xTaskCreate(SampleClient, "client_task", 4000, NULL, 5, NULL);
  vTaskDelete(NULL);
} // End of setup.
void loop() {
} // End of loop
