the necessary documents for ESP32 FCC certification
nzh912
Postby nzh912 » Wed Aug 07, 2019 9:39 am
Hi, currently im in the process of getting the FCC certification on my product, which ESP32 ic on board. I have submitted the (ESP32&ESP8266_RF_Performance_Test) to the UL, but then they replied i still missing the fixed frequency guidelines for getting the FCC certification.
Can anyone please provide me the relevant information.. thank you.
Re: the necessary documents for ESP32 FCC certification
Postby rudi ;-) » Wed Aug 07, 2019 8:51 pm
hi
grab it here (EN Version) or here CN Version
if there are missings parts bump the theme on again.
hope this helps
nzh912
Postby nzh912 » Thu Aug 08, 2019 12:33 am
hi
hope this helps
Hi Rudi,
Thank you in advance.
My product is an onboard IC design, it needs to be done separately the FCC test. so i still need to submit my product to UL for testing FCC. :)
I have submitted the product to UL to test it, but they replied they need the guidelines how to set the fixed frequency and so they can run the test.
I remember last time i can find the documentation of esp32 FCC test guide pdf on the espressif official website, but now i cant find it.
Postby rudi ;-) » Thu Aug 08, 2019 1:04 am
Hi Rudi,
hi,
this?
test tool
test bin files
-> feel free...
"This guide demonstrates how to run an RF related performance test and certification test using an RF tester to check an ESP32 / ESP8266 based product, either functioning as a standalone controller or an integrated part of MCU."
ESP32&ESP8266 RF Performance Test Demonstration
also here: ( please do allways download from origin the last version )
Last Version 2019 - 21 Jan V3.0
ESP_RFtest_and_Certification_tool.zip
(11.93 MiB) Downloaded 665 times
ESP_RFtest_and_Certification_bin.zip
(1.34 MiB) Downloaded 648 times
ESP32&ESP8266_RF_Performance_Test_EN.zip
(19.97 MiB) Downloaded 637 times
Postby rudi ;-) » Thu Aug 08, 2019 1:28 am
if you mean this
this was from 2016
there was also a FCC post on esp32.com
the second post you find the version from 2016
or here(pdf is inlcuded)
or here only the pdf:
ESP32_Certification_and_Test_Guide__EN.pdf
(730.5 KiB) Downloaded 690 times
allways check for newer things.
hope this helps
nzh912
Postby nzh912 » Thu Aug 08, 2019 2:06 am
if you mean this
this was from 2016
hope this helps
Hi Rudi,
Thank you very much :D :D , btw do you have the ESP32_Certification_and Test_Guide in Chinese version ?
Postby rudi ;-) » Thu Aug 08, 2019 2:23 am
Hi Rudi,
:D
ESP32&ESP8266 射频性能测试指南
本测试指南用于指导客户基于 ESP32/ESP8266 设计的产品,使用相关软件和仪器进行射频性能测试或认证测试,并针对“以 Wi-Fi 模组作为独立控制器”或“搭载主机 MCU”两种情况,分别介绍测试方法。
LINK V3 2019 CN
or here:
ESP32&ESP8266_RF_Performance_Test_CN.zip
(20.21 MiB) Downloaded 590 times
PDF (CN) Only
also more tools in CN
feel free..
hope this helps
PS:
i am not sure, was the version 1.0 from DEZ 2016 available in Chinese version too,
i will search the next time and update the post if i find anything in this.
Postby rudi ;-) » Thu Aug 08, 2019 2:40 am
push
yes there was an CN version from 2016 DEZ ,
Screenshot_2019-08-08 Tools_ARchiv2016DEZ 乐鑫.png (63.38 KiB) Viewed 11037 times
but i think not more -online- available.
you can visit web archiv from 2016 online but i think, the attached file ( esp32_cert_test_cn_20161202.zip ) is not available from 2016 there
hope this helps
nzh912
Postby nzh912 » Tue Aug 13, 2019 5:08 am
push
hope this helps
Hi Rudi, Thank you in advance :D
Users browsing this forum: Baidu [Spider], ChatGPT-User, Qwantbot and 1 guest
