wifi scan in non-blocking mode
ry1234
Postby ry1234 » Sat Feb 04, 2017 3:42 am
Hi
I would like to use esp_wifi_scan_start() in non-blocking mode; is there an API or register that allows to check if the scan has completed?
Thanks!
WiFive
Re: wifi scan in non-blocking mode
Postby WiFive » Sat Feb 04, 2017 4:29 am
ry1234
Postby ry1234 » Wed Feb 08, 2017 4:03 pm
Thanks for that.
Does the wifi_scan_start() api initiate an active scan or a passive scan (or both)? I would like to limit to active scan only, couldn't find a way so far to control the behavior beyond a brief mention in the data sheet.
Thanks!
kolban
Postby kolban » Wed Feb 08, 2017 4:39 pm
Howdy ry1234,
Purely because I are a dummy ... can you explain the distinction between an "Active" WiFi scan and a "Passive" WiFi scan?
Neil
ry1234
Postby ry1234 » Wed Feb 08, 2017 5:07 pm
Hi Neil,
Passive scanning is where the client listens to the beacon broadcasts (typical beacon interval is 100 msec).
Active scanning is where the client transmits a probe request and waits for a probe response from all SSIDs that received the request.
ry1234
Postby ry1234 » Wed Feb 08, 2017 5:09 pm
Another piece of information: the esp_wifi_scan_start() API takes 200 msec to return, for a single Wifi channel:
wifi_scan_config_t cfg = {NULL, NULL, 1, false};
ESP_ERROR_CHECK( esp_wifi_scan_start(&cfg, true));
So I suspect it is performing a passive scan (?)
Users browsing this forum: ChatGPT-User, YisouSpider and 1 guest
