Hi ray,
Of course, I should have thought of this fix as well. I'm glad you figured out the root cause. So the actual flash operation time was the same in both cases, but the tick count was reporting incorrectly low ticks on the earlier version?
Angus
Slowness for write operations on flash with esp-idf v3.1.5
Re: Slowness for write operations on flash with esp-idf v3.1.5
Hi ESP_Angus,
yes, the flash erase/write operations time is pretty the same in both cases... First I should have also used at least an other method to evaluate the time intervals but I did not really expect such a FreeRTOS weakness during flash erase/write operations
rayf15
rayf15
Users browsing this forum: Applebot, Baidu [Spider], Bing [Bot], PerplexityBot and 4 guests
