Help with RMT RX
Neuromodulator
Help with RMT RX
Postby Neuromodulator » Fri Sep 06, 2019 3:27 am
Hello!
I've been trying to use the RMT library but I still can't get it to work as I want. I want to use the whole 512 memory blocks to make some measurements, but I still can't figure how to do that. Just to test the RMT code i connected through a cable pin 4 to pin 21. An ouput signal is generated on pin 4 at different spacing intervals and pin 21 is used with the RMT to measure the high and low state durations of pin 4.
My code is as follows:
#include "arduino.h"
#include "driver/rmt.h"
rmt_config_t rmt_rx;
void setup()
    rmt_rx.rmt_mode = RMT_MODE_RX;
    rmt_rx.channel = RMT_CHANNEL_0;
    rmt_rx.clk_div = 1;
    rmt_rx.gpio_num = GPIO_NUM_21;
    rmt_rx.mem_block_num = 8;
    rmt_rx.rx_config.filter_en = false;
    rmt_rx.rx_config.idle_threshold = 0xffff;;
    rmt_config(&rmt_rx);
    rmt_rx_start(rmt_rx.channel, true);
    pinMode(4, OUTPUT);
    Serial.begin(115200);
int count = 0;
unsigned long t = 0;
void loop()
    usleep(1 * count);
    digitalWrite(4, 0);
    usleep(2 * count);
    digitalWrite(4, 1);
    if (millis() - t > 500)
        t = millis();
        count = (count + 1) & 0x1F;
        rmt_memory_rw_rst(rmt_rx.channel);
        rmt_item32_t* item = (rmt_item32_t*)RMT_CHANNEL_MEM(rmt_rx.channel);
        printf("H: %d, ",  item->level0 * item->duration0 +  item->level1 * item->duration1);
        printf("L: %d\n", !item->level0 * item->duration0 + !item->level1 * item->duration1);
For some reason this code does not work at all, unless "rmt_memory_rw_rst()" is moved out of the loop. What am I doing wrong?
Thanks!
Neuromodulator
Re: Help with RMT RX
Postby Neuromodulator » Fri Sep 06, 2019 6:40 am
Don't worry, fixed the issue. I was getting to idle and didn't restart the capture.
lippih
Postby lippih » Sun Dec 06, 2020 8:49 am
Would you kindly explain the exact solution to your problem? If RMT goes to idle, it doesn't restart automatically capturing, when new pulses comming in?
lippih
Users browsing this forum: Google [Bot], Qwantbot and 4 guests
