Toolchain xtensa-esp32-elf-win32-esp32-2019r1-8.2.0.zip missing
Hi Guys
where we find the toolchain esp32-2019r1 ?
the provided link looks 404.
taken from here
thank you!
rudi
taken from here
thank you!
rudi
Re: Toolchain xtensa-esp32-elf-win32-esp32-2019r1-8.2.0.zip missing
can it bee there is a small typo in the link?
https://dl.espressif.com/dl/xtensa-esp3 ... -8.2.0.zip
Latest:
https://dl.espressif.com/dl/xtensa-esp3 ... -win32.zip
thank you!
rudi
ESP32S2:ESP32S2:: dl.espressif.com/dl/xtensa-esp32-elf-win32-esp32-2019r1-8.2.0.zip
LATEST:: dl.espressif.com/dl/xtensa-esp32-elf-gcc8_2_0-esp32-2019r1-win32.zip
Latest:
thank you!
rudi
missing the ESP32S2 toolchain for windows
( not the installer )
rudi
rudi
ok i know, we have from Angus nice how to
and the toolchain is there for ESP32S2 and Windows.
but i get
rudi
but i get
$ make -j4 all
Toolchain path: /opt/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc
WARNING: Toolchain version is not supported: esp32s2-dev-4-g3a626e93
Expected to see version: esp32-2019r1
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
Compiler version: 8.2.0
rudi
rudi
$ printenv PATH
/opt/xtensa-esp32s2-elf/bin:/mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
$ printenv IDF_PATH
c:/msys32/home/sysop/esp32s2/esp-idf
rudi
i think i miss something
the ESP32S2 IDF Path is set, and right, but it points to the esp32 include soc cpu.h
can we Define the target "ESP32S2" or must we Define the target in a Makefile?
rudi
C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32/include/soc/cpu.h: Assembler messages:
C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32/include/soc/cpu.h:59: Error: invalid register 'MEMCTL' for 'wsr' instruction
rudi
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_TARGET="esp32"
# CONFIG_IDF_TARGET_ESP32S2BETA is not set
# SDK tool configuration
txs WiFive,
i will have a try again and post result asap ( not just in time but next 8 hours )And also as a user, is a bit confusing that when you open the sdkconfig you see:
# CONFIG_IDF_TARGET_ESP32 is not set
CONFIG_IDF_TARGET="esp32s2beta"
CONFIG_IDF_TARGET_ESP32S2BETA=y
When the ESP32 target is set
txs WiFive!!!
txs @fasani
rudi
feature/esp32s2beta
rudi
feature/esp32s2beta
ifdef IDF_TARGET
ifneq ($(IDF_TARGET),esp32)
$(error GNU Make based build system only supports esp32 target, but IDF_TARGET is set to $(IDF_TARGET))
endif
else
export IDF_TARGET := esp32
endif
rudi
rudi ;-) wrote: ↑Tue Sep 17, 2019 9:52 am+
feature/esp32s2beta
..Code: Select all
.. ifdef IDF_TARGET ifneq ($(IDF_TARGET),esp32) $(error GNU Make based build system only supports esp32 target, but IDF_TARGET is set to $(IDF_TARGET)) endif else export IDF_TARGET := esp32 endif
changed it to :
ifdef IDF_TARGET
@echo "IDF TARGET WAS SET:" $(IDF_TARGET)
# ifneq ($(IDF_TARGET),esp32)
ifneq ($(IDF_TARGET),esp32s2beta)
# $(error GNU Make based build system only supports esp32 target, but IDF_TARGET is set to $(IDF_TARGET))
$(error GNU Make based build system only supports esp32s2beta target, but IDF_TARGET is set to $(IDF_TARGET))
endif
else
# export IDF_TARGET := esp32
export IDF_TARGET := esp32s2beta
endif
and we get ( automatically )
btw just in time searching the missing added (esp32s2beta) INCLUDE_PATH
In file included from C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32s2beta/include/soc/dport_reg.h:184,
from C:/msys32/home/sysop/esp32s2/esp-idf/components/app_trace/app_trace.c:160:
C:/msys32/home/sysop/esp32s2/esp-idf/components/soc/esp32s2beta/include/soc/dport_access.h:20:10: fatal error: esp32s2beta/dport_access.h: No such file or directory
#include "esp32s2beta/dport_access.h"
compilation terminated.
rudi
