Hello everyone. I have always programmed esp32 using the arduino IDE. But recently I'm thinking of using some more advanced functions that Arduino doesn't allow me yet.
I started by following a guide provided by Espressif (https://docs.espressif.com/projects/esp ... setup.html) but couldn't go very far. When trying to use ESP-IDF Tool Installer I get to a point and get an error.
I can open the program, select the Python I have on the machine, select the Git 2.21.0 I have installed and choose to download ESP-IDF.
The program runs and installs everything, but in the end gives me the following error:
"installation has failed with exit code 2"
This is the part of the log that shows the error:
2019-09-25 14:23:30.467 Installation process succeeded.
2019-09-25 14:23:30.472 Setting PATH for this process: C:\Users\Marco Antônio Vaccar\AppData\Local\Programs\Python\Python37\;C:\Program Files\Git\cmd\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Microchip\xc32\v2.10\bin;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\Brackets\command;C:\Program Files\nodejs\;C:\Program Files\Git\cmd;C:\Users\Marco Antônio Vaccar\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\Marco Antônio Vaccar\AppData\Local\Programs\Python\Python37\;C:\Users\Marco Antônio Vaccar\AppData\Local\Microsoft\WindowsApps;C:\Users\Marco Antônio Vaccar\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\Marco Antônio Vaccar\AppData\Roaming\npm;C:\Program Files\JetBrains\PyCharm Community Edition 2019.2.1\bin
2019-09-25 14:23:30.473 PYTHONPATH=
2019-09-25 14:23:30.473 Extracting temporary file: C:\Users\MARCOA~1\AppData\Local\Temp\is-UCPAL.tmp\7za.exe
2019-09-25 14:23:30.544 Extracting ESP-IDF reference repository: C:\Users\MARCOA~1\AppData\Local\Temp\is-UCPAL.tmp\7za.exe x -oC:\Users\MARCOA~1\AppData\Local\Temp\is-UCPAL.tmp -r -aoa C:\Users\Marco Antônio Vaccar\.espressif\releases\esp-idf-v3.3.zip
2019-09-25 14:23:30.544 Reference repository path: C:\Users\MARCOA~1\AppData\Local\Temp\is-UCPAL.tmp\esp-idf-v3.3
2019-09-25 14:23:30.915 Done, exit code=2
2019-09-25 14:23:30.915 --------
2019-09-25 14:23:30.915 Running command: C:\Users\MARCOA~1\AppData\Local\Temp\is-UCPAL.tmp\7za.exe x -oC:\Users\MARCOA~1\AppData\Local\Temp\is-UCPAL.tmp -r -aoa C:\Users\Marco Antônio Vaccar\.espressif\releases\esp-idf-v3.3.zip
7-Zip (a) 19.00 (x86) : Copyright (c) 1999-2018 Igor Pavlov : 2019-02-21
Scanning the drive for archives:
ERROR: O sistema nÆo pode encontrar o arquivo especificado.
C:\Users\Marco
System ERROR:
2019-09-25 14:23:30.915 Message box (OK):
Installation has failed with exit code 2
Someone know what is happening?
Problems Installing ESP-IDF Tools Installer
Re: Problems Installing ESP-IDF Tools Installer
Which ESP32 IDF you are planning to use? Did you check requirement package lists provided into text file?Hello everyone. I have always programmed esp32 using the arduino IDE. But recently I'm thinking of using some more advanced functions that Arduino doesn't allow me yet.
C:\Users\Marco
System ERROR:
Regards,
Ritesh Prajapati
Ritesh Prajapati
I'm trying to use esp-idf-v3.3
What's requiriments? I'm justo following this guide https://docs.espressif.com/projects/esp ... setup.html. It just says I need a 64bit windows.
There is one requirements text file will be present after cloning ESP32 IDF which you have ever to execute before compiling any sample code.I'm trying to use esp-idf-v3.3
Regards,
Ritesh Prajapati
Ritesh Prajapati
This is completely unrelated to the requirements.txt file...
The issue is due to spaces in the path where IDF Tools are installed. It was fixed in this commit: https://github.com/espressif/esp-idf/co ... 55441cd20a, however we haven't released the new installer with that fix, yet. Could you please try this version? https://dl.espressif.com/dl/esp-idf-tools-setup-2.1.exe
Ok. Thanks for updates.This is completely unrelated to the requirements.txt file...
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User, PerplexityBot and 9 guests
