SDMMC Thread safety
KanyeKanye
SDMMC Thread safety
Postby KanyeKanye » Thu Sep 26, 2019 4:25 pm
I use sd card for recording and storing some important process data.
On core 1, every 200ms, I read one sector (using sdmmc_read_sectors), append 32bytes of new data and save (using sdmmc_write_sectors) the whole sector back.
On core 0 I take care of wifi communication: When user asks for data I read 8 x 64sectors and send it to the user webbrowser.
I do not implement any semaphore on sdmmc driver on my own.
Most of time everything works but from time to time. sdmmc_read_sectors (the one on core 0) results in error 0x107 and
sdmmc_req: sdmmc_host_wait_for_event returned 0x107
is printed. One moment after that, main loop (core 1) is blocked on reading and saving procedure and watchdog is triggered:
[0;31mE (34348) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:[0m
[0;31mE (34348) task_wdt:  - IDLE1 (CPU 1)[0m
[0;31mE (34348) task_wdt: Tasks currently running:[0m
[0;31mE (34348) task_wdt: CPU 0: IDLE0[0m
[0;31mE (34348) task_wdt: CPU 1: process_task[0m
[0;31mE (34348) task_wdt: Aborting.[0m
abort() was called at PC 0x400d290f on core 0
Whats more, watchdog triggering cant fix the problem and there is a dead loop of watchdog triggering on core 0.
Backtrace prints:
0x4008d06d: invoke_abort at /Users/mtm/Development/esp32/esp-idf/components/esp32/panic.c:157
0x4008d3f9: abort at /Users/mtm/Development/esp32/esp-idf/components/esp32/panic.c:174
0x400d2907: task_wdt_isr at /Users/mtm/Development/esp32/esp-idf/components/esp32/task_wdt.c:174 (discriminator 1)
0x400823e5: _xt_lowint1 at /Users/mtm/Development/esp32/esp-idf/components/freertos/xtensa_vectors.S:1153
0x401255cf: ppRxPkt at ??:?
0x4008a3da: ppTask at ??:?
0x4008ffa5: vPortTaskWrapper at /Users/mtm/Development/esp32/esp-idf/components/freertos/port.c:143
Sometimes (not always) there is also printed error:
sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
What can I do for fixing this issue?
ESP_igrr
Re: SDMMC Thread safety
Postby ESP_igrr » Fri Sep 27, 2019 8:49 am
SDMMC driver does not have any internal mutexes to protect from concurrent access. See https://docs.espressif.com/projects/esp ... ead-safety. If you use SDMMC APIs directly (not through a file system) you need to add mutexes around the calls to SDMMC functions.
KanyeKanye
Postby KanyeKanye » Sun Sep 29, 2019 11:07 pm
As suggested, adding mutex semaphore helped and fixed problems
Users browsing this forum: Bytespider, ChatGPT-User, PetalBot, Qwantbot and 8 guests
