Hi rudi thanks for the reply,hi guys
make a full flash erase
windows tool : (erase),
esptool: erase_flash
and then flash it again with arduino ide or like you want.
do not forget to config in arduino the partion option.
i get this in the past if i come from esp-idf to arduino or arduino to esp-idf
if you use different settings in the menuconfig from each in the bin file
then this happens time to time -
also there can be a wrong setup in the spi clk also in the spi mode
or set a bit / old key data format ...
so - clean the flash and it should go on.
rudi![]()
esptool.py erase_flash command does seem to correctly erase the flash, since it then starts showing:
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57Code: Select all
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9232
load:0x40080400,len:6412
entry 0x400806a8
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400806a8
