cross compile - canadian cross and more
Postby rudi ;-) » Tue Jan 26, 2016 2:26 am
btw, the officially toolchain there is a theme folder and workaround here : http://esp32.com/viewtopic.php?f=2&t=26
hi guys
think, its better to make an own thread for this cross compile theme because its become an important member for doings.
i start this for Collection of experience and for exchange of views and tips, because i think,
would perish valuable information in different threads.
there are many ways to build a toolchain.
to build it under linux for
using
in linux,
in windows
to build it under windows, for
using
in windows,
in linux.
the helpers for windows are cygwin and mingw.
i start this theme with this entry:
today i found from lady ada a nice tutorial with cygwin under windows and its the esp3x how to:
https://learn.adafruit.com/compiling-a- ... s/overview
read in, have phun
it has the info to the most error: curses.h and how you can solved this
and you can see and read how simply this patch from 2012 is done. why i have not read this earliest ;-) ..had searched days! :mrgreen:
thanks and credits goes to lady ada
the pdf is here: https://learn.adafruit.com/downloads/pd ... indows.pdf
further links and infos:
https://en.wikipedia.org/wiki/Cross_compiler
http://airs.com/ian/configure/configure_6.html
Re: cross compile - canadian cross and more
Postby rudi ;-) » Thu Jan 28, 2016 1:34 am
looks as if the line kicked against overload.
It always happens when it is not supposed to happen.
forced break are more than 4 hours
:mrgreen:
broken lines and more in the log
Postby rudi ;-) » Thu Jan 28, 2016 2:27 am
now github is closed
so i close for this night too
see you at the weekend.
Users browsing this forum: Applebot and 2 guests
