FatFs does not work on encrypted partition
Mikhail Khalizev
Re: FatFs does not work on encrypted partition
Postby Mikhail Khalizev » Mon Oct 21, 2019 5:13 am
Hi.
I'm usung the latest version of ESP-IDF from 'release/v3.3' branch [0a0f2ca].
Steps to reproduce:
1. Take 'esp-idf\examples\storage\wear_levelling'.
2. Set 'encryption' flag on 'storage' partition in 'partitions_example.csv' file.
3. Don't enable flash encryption in 'sdkconfig'.
4. Upload to device.
As result I see logs:
I (174) example: Mounting FAT filesystem
I (184) example: Opening file
E (195) example: Failed to open file for writing
jcsbanks
Postby jcsbanks » Mon Oct 21, 2019 7:38 am
I got into the habit of only adding the encryption tags in the partition table only when flash encryption was enabled. It was not mentioned in docs, but it solved a few problems if I recall switching between flash encryption on or off.
Users browsing this forum: Bytespider, Google [Bot], meta-externalagent, Semrush [Bot] and 5 guests
