problem developing http server
countxerox
Postby countxerox » Fri Feb 10, 2017 5:31 pm
I'd like to serve up an html page, my server works fine with simple pages but when I try to use svg I get errors compiling and the build failed.
const static char http_index_html[] =
		"<html><body><svg width=100% height=100% viewbox="0 0 200 200" id="svg"><rect .... etc
/home/rob/esp32/workspace/myapp/main/./main.c:87:53: error: expected ',' or ';' before numeric constant
How should I define html the page properly?
Rob
countxerox
Re: problem developing http server
Postby countxerox » Sun Feb 12, 2017 2:46 pm
Hi, I found out the " characters were the problem, so I can easily escape them like \".
but is there a better way to store a static page on the esp32? As I develop the page further, it's getting boring adding \'s again and again.
Rob
Postby rudi ;-) » Sun Feb 12, 2017 10:33 pm
Rob
hi
there are more ways for this..
one here:
try this:
example your file is named fine.txt
put this file in the folder of your project
example
\main\fine.txt
in your code write:
extern const uint8_t my_extern_file[] asm("_binary_fine_txt_start");
then you can use it like you want to do:
printf("%s", my_extern_file);
printf((char *)my_extern_file);
similar to this
you can create a html file like it is ( fine.html )
extern const uint8_t my_extern_file[] asm("_binary_fine_html_start");
same procedure
// and so on
// socket_send((char *)my_extern_file,......
if you compile your project
the file gets symbol and is fixed in the flash on write the bin to esp32
let me know how you get on in this
hope this helps
edit:
Example: fine.tx
░ (_.·´/|\`·._)(¯ `·.\|/.·´¯)
░ ░ (_.:._)…(¯ `·.(۞).·´¯)
░♥░ (¯`:´¯)░(_.·´/|\`·._)
♥░.(¯ `·.\|/.·´¯) ::(_.:._)
░ ░(_.·´/|\`·._)
░♥♥». (_.:._)░
Example: SSL Zertifikate
OpenSSL Server Example
kolban
Postby kolban » Mon Feb 13, 2017 12:06 am
Another possibility is to use the "xxd" tool. This takes an arbitrary file as input (binary or text) and can produce a header file that contains the data in the file that is safe to include in your other C programs. See:
http://linuxcommand.org/man_pages/xxd1.html
countxerox
[solved] problem developing http server
Postby countxerox » Tue Feb 14, 2017 8:51 pm
Thanks both, this is great advice. :)
I added a line in component.mk to help the complier find the file I guess ...
COMPONENT_EMBED_TXTFILES := fine.html
For netconn, the sizeof the data to send ...
extern const uint8_t fine_html_start[] asm("_binary_fine_html_start");
extern const uint8_t fine_html_end[] asm("_binary_fine_html_end");
const unsigned int fine_html_bytes = fine_html_end - fine_html_start;
Then serving up the page is just ...
netconn_write(conn, (char *)fine_html_start, fine_html_bytes, NETCONN_NOCOPY);
Rob
Angus
Postby Angus » Tue Feb 14, 2017 11:19 pm
Hi Rob,
Glad you got this working well. For the reference of anyone who finds this later on, the documentation for the COMPONENT_EMBED_TXTFILES/COMPONENT_EMBED_FILES feature is here:
http://esp-idf.readthedocs.io/en/latest ... inary-data
Angus
Users browsing this forum: ChatGPT-User, DuckDuckGo [Bot] and 6 guests
