TCPIP get/set hostname always fails
JadElClemens
Postby JadElClemens » Tue Nov 12, 2019 11:02 pm
I noticed since upgrading to ESP-IDF v4.0-beta2 from v3.2 that my calls to tcpip_adapter_{get,set}_hostname now fail. The error code for getting the hostname is ESP_ERR_TCPIP_ADAPTER_INVALID_PARAMS and for setting it is ESP_ERR_TCPIP_ADAPTER_IF_NOT_READY, though I can say with confidence that in both cases the error is because p_netif within the IDF TCPIP/LWIP code ends up as NULL.
My code works somewhat as follows:
  • Create default event loop and register handler for WIFI_EVENT and IP_EVENT groups
  • Code: Select all
    tcpip_adapter_init()
  • Code: Select all
    esp_wifi_init(WIFI_INIT_CONFIG_DEFAULT());
    esp_wifi_set_storage(WIFI_STORAGE_RAM);
    esp_wifi_set_mode(WIFI_MODE_STA);
    (each statement is error-checked)
  • In WiFi/IP event handler:
    switch(event_id) {
    	case WIFI_EVENT_STA_START:
    		tcpip_adapter_set_hostname(TCPIP_ADAPTER_IF_STA, [hostname])
    		break;
Am I missing a step here or is it a bug in the IDF? This code worked perfectly fine with v3.2 (except that I had to change the loop handler to use the new esp_event component).
WiFive
Re: TCPIP get/set hostname always fails
Postby WiFive » Wed Nov 13, 2019 2:23 am
Have a log output at debug log level?
JadElClemens
Postby JadElClemens » Thu Nov 14, 2019 5:46 pm
Sure thing
https://privatebin.net/?239d6ac0b61a402 ... GsALbqeBCt
I removed some irrelevant parts and personal log information that had nothing to do with the WiFi subsystem.
WiFive
Postby WiFive » Fri Nov 15, 2019 12:06 am
I guess it could be because WIFI_EVENT_STA_START dispatches the tcpip_adapter_start to a worker thread and then calls your event handler so it is possible the worker thread hasn't actually created the netif when your function is called. Maybe a retry loop with a vtaskdelay(1)?
i_am_mrp
Postby i_am_mrp » Sat Feb 01, 2020 7:53 am
I am seeing the same problem, however it was intermittent. This makes me think there is a timing or race condition causing the problem. At my current app code level though, it is failing every time. I am on the ESP-IDF Pre-release v4.0-beta2.
The correct place to set the host is after start and before connect, so I believe the call is in the right place.
Since the IDF Default-Event-Loop does the event dispatch, the notion of doing a busy-delay in a handler is not a good idea as a solution.
In any case I did try a variety of spin loop counts, with varying delays, and all attempts come back with 0x5002 ESP_ERR_TCPIP_ADAPTER_IF_NOT_READY.
I was able to trim my app down to only the wifi handling and interestingly the host name setting is working :( At this point the major difference after a number of trim down exercises is running the webserver. Not sure how this changes things but that's the delta between working and not working.
Users browsing this forum: Baidu [Spider], Bytespider, Google [Bot], Qwantbot and 1 guest
