Alternative to ESP_ERROR_CHECK
kolban
Postby kolban » Tue Feb 14, 2017 2:30 am
The ESP-IDF provides a useful macro called ESP_ERROR_CHECK() that takes a statement as a parameter. If the statement does NOT return ESP_OK, then we assert and log the line. Unfortunately, this doesn't include the error code value that was actually returned by the statement.
Here is an alternative definition which logs the error code in addition to throwing an assertion:
#undef ESP_ERROR_CHECK
#define ESP_ERROR_CHECK(x)   do { esp_err_t rc = (x); if (rc != ESP_OK) { ESP_LOGE("err", "esp_err_t = %d", rc); assert(0 && #x);} } while(0);
Angus
Re: Alternative to ESP_ERROR_CHECK
Postby Angus » Tue Feb 14, 2017 3:14 am
Hi Kolban,
Good addition. Could you please send this as a pull request on github? We'll likely incorporate it into esp-idf.
Angus
BuddyCasino
Postby BuddyCasino » Fri Mar 31, 2017 6:53 pm
Very nice! This has bugged me too, didn't know it is that easy to contribute.
Bmillier
Postby Bmillier » Mon Sep 25, 2017 5:34 pm
Hi Neil
This is off topic: I love your book. Have used it on several projects, the latest being a learning IR remote/ wifi blaster using RMT peripheral. I note on page 255 you show max values of 65535 for the 15- bit timing value saved by the RMT peripheral. This should be 32767.
Using the Arduino IDE and my own drivers, I have gotten the IR transmit function working fine using
LIRC conf files for the IR data structure, as a test. I just got the basic IR receive function working for the "learning" part, but there's more work needed to handle the wide range of IR signals that the different remotes emit.
This would be easier to do if I were using the Espressif IDF, but that's more than I want to bite off right now.
kolban
Postby kolban » Mon Oct 30, 2017 4:45 am
Thank you sir. Documentation changes to 32767.
jeanleflambeur
Postby jeanleflambeur » Wed Nov 01, 2017 8:48 pm
Pls use a mangled name for the internal macro variable rc.
That's because in C/C++ this statement actually compiles:
int a = a;
It results in variable a being uninitialized essentially.
So with your macro, this code would have unexpected results:
int rc = 7;
ESP_ERROR_CHECK(initialize_remote_control(rc));
The rc value passed to initialize_remote_control is actually random, not 7.
Also, this code would not compile because what is passed to the function is the internal esp_err_t instead of the string:
esp_err_t  initialize_db(const string& name)
int  main(int argc, const char* argv[])
	string rc = "db1";
	ESP_ERROR_CHECK(initialize_db(rc));
	return 0;
I have a PR about this issue without any answer so far: https://github.com/espressif/esp-idf/pull/1109
The solution is simple - just call that internal variable smth else like __internal_rc__
