i2s parallel only works with one dma descriptor
Baldhead
Postby Baldhead » Tue Nov 26, 2019 1:06 am
I am developing my own i2s paralle 8 bits with dma library(static allocation memory).
When i write to the parallel port using only one descriptor(4092 uint8_t), the clock time to send, for example, 1000 uint8_t at 10 MHz is 100 microseconds(1000/10 000 000).
Apparently all ok with only one descriptor.
When i use more than one descriptor, the clock time to send, for example, 7680 uint8_t at 10 MHz is 1536 microseconds.
Should be half of this value 768 microseconds( 7680 / 10 000 000 ). I don't know why it's taking twice as long.
In annex follow an oscilloscope image of 7680 uint8_t at 10 MHz.
The yellow waveform are the clock(10MHz).
The blue waveform are the D0 channel data.
I initialize the buffer with zeros, but in D0 channel appears some weird data.
Also with only one descriptor, each time that i send the data i perform these instructions( partial code below ):
I2SX.conf.tx_start = 0; // Set this bit to start transmitting data. (R/W).
I2SX.conf.tx_reset = 1; // Set this bit to reset the transmitter. (R/W)
I2SX.conf.tx_reset = 0; // Set this bit to reset the transmitter. (R/W)
I2SX.fifo_conf.dscr_en = 0; // Set this bit to enable I2S DMA mode. (R/W).
Partial code below: VVVV
    fill_dma_descriptor_b(  (uint32_t) 4 * length  );    // fill_dma_descriptor_b( length );  lenght in bytes.
    I2SX.out_link.addr = (uint32_t) &dma_desc_buf_b[0];
    I2SX.out_link.start = 1;          // Set this bit to start outlink descriptor. (R/W).
    I2SX.fifo_conf.dscr_en = 1;    // Set this bit to enable I2S DMA mode. (R/W).
    I2SX.conf.tx_start = 1;           // Set this bit to start transmitting data. (R/W).
    while ( ! ( I2SX.state.tx_idle ) )   // The status bit of the transmitter. 1: the transmitter is idle. 0: the transmitter is busy.(RO)
Right now i'm not using i2s module interrupt.
Could this be the problem ?
Any other suggestions is appreciated.
Thank's.
Baldhead
Re: i2s parallel only works with one dma descriptor
Postby Baldhead » Tue Nov 26, 2019 1:09 am
i2SX = i2s0 in my application driver.
Postby Sprite » Tue Nov 26, 2019 2:09 am
Smells like you're filling the DMA descriptor wrong, but you're not including that code...
Baldhead
Postby Baldhead » Tue Nov 26, 2019 3:54 am
Hi ESP_Sprite,
Follow the code you commented.
// static int IRAM_ATTR fill_dma_descriptor_a( uint32_t length )          IRAM_ATTR    ????????????
// verify if sosf = 1  ?
#define buffer_size 30720     // uint8_t size
static lldesc_t dma_desc_buf_a[8];     // DMA_ATTR ????
DMA_ATTR uint16_t buffer_a[ buffer_size/2 ];
static int fill_dma_descriptor_a ( uint32_t length )    //  uint32_t length em bytes.
    if ( length > buffer_size )  return -1;    // length = numero de pixels*2. 1 pixel = 2 bytes. 313 ns.
    if ( length == 0 )           return -2;    // 300 ns.
    if ( length <= 4092 )    // only need one single descriptor. // 740 ns.
        dma_desc_buf_a[0].size = 4092;// The size must be word-aligned. I can define 4092 here, but the dma only send ".length" bytes.
	dma_desc_buf_a[0].length = length;
	dma_desc_buf_a[0].offset = 0;
	dma_desc_buf_a[0].sosf = 0;
	dma_desc_buf_a[0].eof = 1;	    // indicates that are the end of the linked list.
	dma_desc_buf_a[0].owner = 1;     // the allowed operator is the DMA controller.
	dma_desc_buf_a[0].buf = (uint8_t*) &buffer_a[0];
	dma_desc_buf_a[0].qe.stqe_next = ( lldesc_t* ) NULL;    // last node of linked list.
        return 1;    // ok.
    // if ( length > 4092 )   // Need more than one descriptor.
    static uint32_t fullBufferNum;                     // full buffer descriptor number(4092 bytes).
    fullBufferNum = (uint32_t) length / 4092;    // integer division.
    static uint32_t remainderBufferNum;  // A single descriptor with buffer between (1 and 4091 bytes). 0 or 4092 bytes fall within "fullBufferNum". 0 bytes -> fullBufferNum only. 4092 bytes -> fullBufferNum + 1.
    remainderBufferNum = ( length % 4092 );  // Returns the remainder of the division of the length/4092 ( integer number ).
        // Example: length/4092 = 14002 / 4092 = 3 e remainder = 1726. 3*4092 + 1726 = 14002.
    static uint32_t i = 0;    // for iteration.
    for ( i = 0 ; i < fullBufferNum ; i++ )
	    dma_desc_buf_a[i].size = 4092;    // The size must be word-aligned. The size of the buffer corresponding to the current linked list.
	    dma_desc_buf_a[i].length = 4092;  // The number of valid bytes in the buffer corresponding to the current linked list. The field value indicates the number of bytes to be transferred to/from the buffer denoted by word DW1.
	    dma_desc_buf_a[i].offset = 0;
	    dma_desc_buf_a[i].sosf = 0;
	    dma_desc_buf_a[i].eof = 0;	     // indicates that it is not the end of the linked list.
	    dma_desc_buf_a[i].owner = 1;    // the allowed operator is the DMA controller.
	    dma_desc_buf_a[i].buf = (uint8_t*) ( ( &buffer_a[0] ) + ( 4092 * i ) );
	    dma_desc_buf_a[i].qe.stqe_next = ( lldesc_t* ) &dma_desc_buf_a[ i+1 ];
    if ( remainderBufferNum == 0 )    // integer division. Don't need allocate another descriptor.
        dma_desc_buf_a[ fullBufferNum - 1 ].eof = 1;    // indicates that is the end of linked list.
        dma_desc_buf_a[ fullBufferNum - 1 ].qe.stqe_next = ( lldesc_t* ) NULL;
        return 2;  // with 2 full descriptors(8184) = 1.63 us. with 7 full descriptors(28644) = 4.25 us.
    else  // Need to allocate (statically) 1 more descriptor.
        dma_desc_buf_a[fullBufferNum].size = 4092;// The size must be word-aligned. I can define 4092 here, but the dma only send ".length" bytes.
	dma_desc_buf_a[fullBufferNum].length = remainderBufferNum;
	dma_desc_buf_a[fullBufferNum].offset = 0;
	dma_desc_buf_a[fullBufferNum].sosf = 0;
	dma_desc_buf_a[fullBufferNum].eof = 1;	        // indicates that is the end of linked list.
	dma_desc_buf_a[fullBufferNum].owner = 1;      // the allowed operator is the DMA controller.
	dma_desc_buf_a[fullBufferNum].buf = (uint8_t*) ( &buffer_a[0] ) + ( 4092 * fullBufferNum );
	dma_desc_buf_a[fullBufferNum].qe.stqe_next = ( lldesc_t* ) NULL;    // last node.
        return 3;  // with input parameter length = 4093 -> 1.47 us. with input parameter length = 30720 -> 4.7 us.
        printf("fullBufferNum = %d\n", fullBufferNum );
        printf("remainderBufferNum = %d\n", remainderBufferNum );
        printf(" &buffer_a = %p\n", &buffer_a );
        printf(" &buffer_b = %p\n", &buffer_b );
        static uint32_t j = 0;    // for iteration.
        for ( j = 0 ; j < sizeof(dma_desc_buf_a)/sizeof(dma_desc_buf_a[0]) ; j++ )
            printf("dma_desc_buf_a[%d].size = %d\n", j, dma_desc_buf_a[j].size );
            printf("dma_desc_buf_a[%d].length = %d\n", j, dma_desc_buf_a[j].length );
            printf("dma_desc_buf_a[%d].offset = %d\n", j, dma_desc_buf_a[j].offset );
            printf("dma_desc_buf_a[%d].sosf = %d\n", j, dma_desc_buf_a[j].sosf );
            printf("dma_desc_buf_a[%d].eof = %d\n", j, dma_desc_buf_a[j].eof );
            printf("dma_desc_buf_a[%d].owner = %d\n", j, dma_desc_buf_a[j].owner );
            printf("dma_desc_buf_a[%d].buf = %p\n", j, dma_desc_buf_a[j].buf );
            printf("dma_desc_buf_a[%d].qe.stqe_next = %p\n", j, dma_desc_buf_a[j].qe.stqe_next );
            printf("\n");
            printf("&dma_desc_buf_a[%d] = %p\n", j+1, &dma_desc_buf_a[j+1] );
            printf("\n\n");
You can use the printf to check the code.
For me looks ok this code.
Thank's.
Baldhead
Postby Baldhead » Tue Nov 26, 2019 4:10 am
Actually the new code are below, because i need copy an uint8_t buffer to an uint32_t buffer (very bad i2s design i think, unless there is another way), but the espressif team don't respond me(I'm not being rude).
#define buffer_size 30720  // byte size
DMA_ATTR uint16_t buffer_a[buffer_size/2];
DMA_ATTR uint32_t buf_a[buffer_size/4];    // dma buffers. // buffer_size/4 = 7680 bytes.   uint32_t buf_a -> 30720 bytes.
// static int IRAM_ATTR fill_dma_descriptor_a( uint32_t length )     // IRAM_ATTR    ????
// verificar se sosf = 1.
    if ( length <= 4092 )    // Soh precisa um descriptor. // 740 ns.
        dma_desc_buf_a[0].size = 4092;    // The size must be word-aligned. Eu posso definir 4092 aqui, porem o dma soh ira enviar ".length" bytes.
	    dma_desc_buf_a[0].eof = 1;	    // indica que eh o final da lista.
	    dma_desc_buf_a[0].buf = (uint8_t*) &buf_a[0];
	    dma_desc_buf_a[0].qe.stqe_next = ( lldesc_t* ) NULL;    // ultimo nó da lista ligada.
        return 1;    // ok.
    // if ( length > 4092 )  // Precisa mais que um descriptor.
    static uint32_t fullBufferNum;               // Numero de descriptors com buffer cheio(4092 bytes).
    fullBufferNum = (uint32_t) length / 4092;    // Divisao inteira.
    static uint32_t remainderBufferNum;          // Um unico descriptor com buffer entre ( 1 e 4091 bytes). 0 ou 4092 bytes se enquadra em "fullBufferNum". 0 bytes -> somente fullBufferNum. 4092 bytes -> fullBufferNum + 1.
    remainderBufferNum = ( length % 4092 );      // Retorna o resto da divisao de length/4092 ( numero inteiro ).
                                                 // Exemplo: length/4092 = 14002 / 4092 = 3 e resto = 1726. 3*4092 + 1726 = 14002.
	    dma_desc_buf_a[i].eof = 0;	    // indica que não eh o final da lista.
	    dma_desc_buf_a[i].buf = (uint8_t*) ( ( &buf_a[0] ) + ( 4092 * i ) );
    if ( remainderBufferNum == 0 )    // divisao inteira. Não precisa mais alocar nenhum descriptor.
        dma_desc_buf_a[ fullBufferNum - 1 ].eof = 1;    // indica que eh o final da lista.
        return 2;  // Com 2 full descriptors(8184) = 1.63 us. Com 7 full descriptors(28644) = 4.25 us.
    else  // Precisa alocar(estaticamente) mais 1 descriptor.
        dma_desc_buf_a[fullBufferNum].size = 4092;    // The size must be word-aligned. Eu posso definir 4092 aqui, porem o dma soh ira enviar ".length" bytes.
	    dma_desc_buf_a[fullBufferNum].eof = 1;	    // indica que eh o final da lista.
	    dma_desc_buf_a[fullBufferNum].buf = (uint8_t*) ( &buf_a[0] ) + ( 4092 * fullBufferNum );
	    dma_desc_buf_a[fullBufferNum].qe.stqe_next = ( lldesc_t* ) NULL;    // ultimo nó da lista ligada.
        printf(" &buf_a = %p\n", &buf_a );
        printf(" &buf_b = %p\n", &buf_b );
            printf("\n");
            printf("\n\n");
        return 3;  // Com input parameter length = 4093 -> 1.47 us. Com input parameter length = 30720 -> 4.7 us.
int i2s_lcd_write_data ( uint32_t length, bool buffer_id )   // length = numero de bytes. length <= 7680.
    static uint32_t i;
    static uint8_t* ptr = NULL;
    if ( length > buffer_size/4  )    // Length > buffer capacity. Usar printf. buffer_size/4 = 30720/4 = 7680 bytes.
        printf( "error: length > buffer_size/4.\n\n" );
        return -1;
    if ( buffer_id == 0 )
        ptr = (uint8_t *) &buffer_a;    // buffer_a é uint16_t.
        for ( i = 0 ; i < length ; i = i + 2 )    // length <= 7680 bytes.  loop no maximo 7680/2 = 3840 vezes.
            buf_a[ i ] = ptr[ i ];    // o endereco de buf_a incrementa em 4 bytes enquanto o endereco de buffer_a(ptr) incrementa em 1 byte.
            buf_a[ i + 1 ] = ptr[ i + 1 ];
        fill_dma_descriptor_a( (uint32_t) 4 * length );  // ( 4 * length ) = converte de byte(8 bits) para word(32bits). // fill_dma_descriptor_a( length );
        I2SX.out_link.addr = (uint32_t) &dma_desc_buf_a[0];
    else
        ptr = (uint8_t *) &buffer_b;    // buffer_a é uint16_t.
            buf_b[ i ] = ptr[ i ];    // o endereco de buf_a incrementa em 4 bytes enquanto o endereco de buffer_a(ptr) incrementa em 1 byte.
            buf_b[ i + 1 ] = ptr[ i + 1 ];
    tx_reset( );           // Set this bit to reset the transmitter. (R/W)
    //fifo_tx_reset( );
    //dma_tx_reset( );
    return 2019;
Baldhead
Postby Baldhead » Tue Nov 26, 2019 8:18 pm
Now i add the following instructions:
* fifo_tx_reset( );
* dma_tx_reset( );
Besides:
* tx_reset( );
static void fifo_tx_reset( )
    I2SX.conf.tx_fifo_reset = 1;    // Set this bit to reset the transmit FIFO. (R/W)
    I2SX.conf.tx_fifo_reset = 0;
static void dma_tx_reset( )
    I2SX.lc_conf.out_rst = 1;    // Set this bit to reset out DMA FSM. (R/W)
    I2SX.lc_conf.out_rst = 0;    // FSM = Finite State Machine.
    static uint32_t i;
        return -1;
            buf_a[ i ] = ptr[ i ]; // o endereco de buf_a incrementa em 4 bytes enquanto o endereco de buffer_a(ptr) inc em 1 byte.
    else
            buf_b[ i ] = ptr[ i ];    // o endereco de buf_a incrementa em 4 bytes enquanto o endereco de buffer_a(ptr) inc em 1 byte.
    if ( I2SX.int_st.out_dscr_err )
        printf( "Dma error, interrupt status: 0x%08x", I2SX.int_st.val );
    fifo_tx_reset( );
    dma_tx_reset( );
    return 2019;
Now when use more than one descriptor, the clock time to send, for example, 7680 uint8_t at 10 MHz is
The time is correct now, but only send one time and stop.
Also in the D0 channel appears some weird data yet.
Do i need to reset ahb bus or something like that ?
I will try.
I2S_LC_CONF_REG.
I2S_AHBM_RST Set this bit to reset AHB interface of DMA. (R/W)
I2S_AHBM_FIFO_RST Set this bit to reset AHB interface cmdFIFO of DMA. (R/W)
Thank's.
Baldhead
Postby Baldhead » Tue Nov 26, 2019 8:39 pm
I used only the function below to isolate the above behavior.
* dma_tx_reset( );
With the function
fifo_tx_reset( );
the time error remained(1536 us).
Baldhead
Postby Baldhead » Tue Nov 26, 2019 11:23 pm
"Smells like you're filling the DMA descriptor wrong, but you're not including that code..."
If i was filling the DMA descriptor wrong, the bit "I2S0.int_st.out_dscr_err" should not be set ?
The bit "I2S0.int_st.out_dscr_err" are always zero.
I am not enabling the interrupt and i don't know if the bit "I2S0.int_st.out_dscr_err" works without enabling interrupt.
Some others suggestions ???
Thank's.
Baldhead
Postby Baldhead » Wed Nov 27, 2019 2:46 am
This function is better with or without this attribute "IRAM_ATTR" ???
"static int fill_dma_descriptor_a( uint32_t length )"
"static int IRAM_ATTR fill_dma_descriptor_a( uint32_t length )"
and,
This buffer is better with or without this attribute "DMA_ATTR" ???
static DMA_ATTR lldesc_t dma_desc_buf_a[8];
Thank's.
Baldhead
Postby Baldhead » Wed Nov 27, 2019 3:07 am
I encounter two problems in my function "static int fill_dma_descriptor_a ( uint32_t length )".
First bug:
Initially the buffer was uint8_t, so, the uint8_t buffer pointer increased the address by one address position ( ie: 4092 * i * 1 ).
dma_desc_buf_a.buf = (uint8_t*) ( ( &buf_a[0] ) + ( 4092 * i ) );
After, i changed the buffer to uint32_t, so, the uint32_t buffer pointer increased the address by four address position ( ie: 4092 * i * 4 ).
So, i changed to "1023 * i".
dma_desc_buf_a.buf = (uint8_t*) ( ( &buf_a[0] ) + ( 1023 * i ) );
Second bug:
dma_desc_buf_a[fullBufferNum].buf = (uint8_t*) ( ( &buf_a[0] ) + ( 1023 * fullBufferNum ) );
An extra parenthesis was missing in the formula: (uint8_t*) ( &buf_a[0] ) + ( 1023 * fullBufferNum )
I changed to: (uint8_t*) ( ( &buf_a[0] ) + ( 1023 * fullBufferNum ) )
The compiler calculated wrong way the address of the "dma_desc_buf_a[fullBufferNum].buf".
