uart_set_line_inverse() mask parameter undefined
Jami17
Postby Jami17 » Mon Dec 30, 2019 2:19 pm
I just downloaded the current IDF.
Compiling my project now results in errors:
uart_set_line_inverse(n, UART_INVERSE_TXD);
UART_INVERSE_TXD is not defined anymore in the new IDF. The doucmentation is also unclear:
Choose the wires that need to be inverted. Using the ORred mask of uart_signal_inv_t
uart_signal_inv_t is also undefined.
What value is required when TXD is to be inverted?
Why has UART_INVERSE_TXD been dropped?
ben_mkiv
Re: uart_set_line_inverse() mask parameter undefined
Postby ben_mkiv » Sun Jan 12, 2020 6:50 pm
looks like this got renamed to UART_SIGNAL_TXD_INV
Jami17
Postby Jami17 » Mon Jan 13, 2020 2:04 pm
Yes, I had also asked here and got a reply
https://github.com/espressif/esp-idf/issues/4581
Users browsing this forum: Baidu [Spider], Google [Bot], PetalBot, Semrush [Bot], trendictionbot and 1 guest
