SIM800 TTGO TCALL pppos_client
Does anybody know what is the configuration for TTGO TCALL to run pppos_client example ?
Currently I put :
CONFIG_MODEM_TX_PIN=26
CONFIG_MODEM_RX_PIN=27
But I do not find the values for these ones and the example does not work :
CONFIG_MODEM_RTS_PIN=
CONFIG_MODEM_CTS_PIN=
I took info from :https://github.com/Xinyuan-LilyGO/TTGO- ... pinout.jpg
Regards,
Currently I put :
Regards,
Re: SIM800 TTGO TCALL pppos_client
From the diagram you linked, only Rx & Tx are connected (RTS & CTS are not used).
Are you toggling the PWKEY signal?
From the manual:
From the manual:
PWRKEY should be pulled low at least 1 second and then released to power on/down the module.
Thanks for your answer.
I will test it and give you a feedback.
It is not working.
I still have crash.
I still have crash.
(297) boot: Loaded app from partition at offset 0x10000
I (297) boot: Disabling RNG early entropy source...
I (298) cpu_start: Pro cpu up.
I (301) cpu_start: Application information:
I (306) cpu_start: Project name: esp-idf
I (311) cpu_start: App version: v3.3
I (316) cpu_start: Compile time: Oct 31 2019 15:06:55
I (322) cpu_start: ELF file SHA256: 1f5f0b574ec01900...
I (328) cpu_start: ESP-IDF: v3.3
I (332) cpu_start: Starting app cpu, entry point is 0x4008107c
0x4008107c: call_start_cpu1 at D:/esp/esp-idf/components/esp32/cpu_start.c:270
I (0) cpu_start: App cpu up.
I (343) heap_init: Initializing. RAM available for dynamic allocation:
I (350) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (356) heap_init: At 3FFB4148 len 0002BEB8 (175 KiB): DRAM
I (362) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (368) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (375) heap_init: At 400896AC len 00016954 (90 KiB): IRAM
I (381) cpu_start: Pro cpu start user code
I (175) cpu_start: Chip Revision: 1
I (176) cpu_start: Starting scheduler on PRO CPU.
I (22282) uart: queue free spaces: 30
E (22782) esp-modem: esp_modem_dte_send_cmd(215): process command timeout
E (22782) dce_service: esp_modem_dce_sync(48): send command failed
E (22782) sim800: sim800_init(460): sync failed
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:Re: SIM800 TTGO TCALL pppos_client
I debugged and I found where is the problem but I do not know how to solve it.
In esp_modem.c, line 215
The command is sent to UART because the log shows the result >=0.
The next line xSemaphoreTake has an error and then, it crashes the program.
Does somebody know what is happening and how to solve ?
Regards,
/* Send command via UART */
ESP_LOGI("TAG", "UART WRITE RESULT : %d",uart_write_bytes(esp_dte->uart_port, command, strlen(command)));
/* Check timeout */
MODEM_CHECK(xSemaphoreTake(esp_dte->process_sem, pdMS_TO_TICKS(timeout)) == pdTRUE, "process command timeout", err);The next line xSemaphoreTake has an error and then, it crashes the program.
Regards,
Hi! The TX pin shoud be 27 and RX pin 26. RTS and CTS doesn't matter. Don't forget that you should turn on the sim800 module before call sim800_init().
Hi! You should configure as follow:Hello,
Currently I put :
Regards,
CONFIG_MODEM_TX_PIN=27
CONFIG_MODEM_RX_PIN=26
CONFIG_MODEM_RTS_PIN= doesn't matter
CONFIG_MODEM_CTS_PIN= doesn't matter
Don't forget that you should turn on the sim800 module before call sim800_init(dte) function.
somothing like this:
#define SIM800_PWKEY 4
#define set_sim800_pwkey() gpio_set_level(SIM800_PWKEY,1)
#define clear_sim800_pwkey() gpio_set_level(SIM800_PWKEY,0)
#define SIM800_RST 5
#define set_sim800_rst() gpio_set_level(SIM800_RST,1)
#define clear_sim800_rst() gpio_set_level(SIM800_RST,0)
#define SIM800_POWER 23
#define set_sim800_pwrsrc() gpio_set_level(SIM800_POWER,1)
#define clear_sim800_pwrsrc() gpio_set_level(SIM800_POWER,0)
void sim800_turnon(void)
gpio_config_t io_conf;
io_conf.mode = GPIO_MODE_OUTPUT;
io_conf.pin_bit_mask = (1<<SIM800_PWKEY)+(1<<SIM800_RST)+(1<<SIM800_POWER);
io_conf.pull_down_en = 0;
io_conf.pull_up_en = 0;
gpio_config(& io_conf);
ESP_LOGI(TAG, "Apagando...");
set_sim800_pwkey();
set_sim800_rst();
clear_sim800_pwrsrc();
vTaskDelay(1000/portTICK_PERIOD_MS);
set_sim800_pwrsrc();
ESP_LOGI(TAG, "Iniciando...");
clear_sim800_pwkey();
set_sim800_pwkey();
set_sim800_rst();
clear_sim800_rst();
set_sim800_rst();
vTaskDelay(3000/portTICK_PERIOD_MS);
Power up sequence that works for me ...
gpio_set_direction(MODEM_PWKEY, GPIO_MODE_OUTPUT);
gpio_set_direction(MODEM_RST, GPIO_MODE_OUTPUT);
gpio_set_direction(MODEM_POWER_ON, GPIO_MODE_OUTPUT);
gpio_set_level(MODEM_PWKEY, LOW);
gpio_set_level(MODEM_RST, HIGH);
gpio_set_level(MODEM_POWER_ON, HIGH);
vTaskDelay(1500/portTICK_RATE_MS);
gpio_set_level(MODEM_PWKEY, HIGH);
vTaskDelay(15000/portTICK_RATE_MS);
As per the datasheet PWKEY must be pulled high after 1-2 sec
The 15 second delay in my case was to ensure the SIM card is ready (+CPIN=READY comes very late in my T-CALL module, without which IMSI will fail)
Hi Both,
Any chance you can post the full code that you used to get this working? I have tried both of your suggestions by modifying the esp example code and still can't get it working.
@gleiva when I did your suggestion, I got a core dump when calling clear_sim800_pwkey
@bharath when I did your suggestion, fails with the following errors
(17479) esp-modem: esp_modem_dte_send_cmd(215): process command timeout
(17479) dce_service: esp_modem_dce_sync(48): send command failed
(17479) sim800: sim800_init(460): sync failed
I have tried all sorts to try and get this example working but am now at a loss.
thanks
Lee.
thanks
Lee.
Users browsing this forum: Applebot, Baidu [Spider], ChatGPT-User, Google [Bot], Semrush [Bot] and 9 guests
