ugfx_example does not build with IDF 4.0
Paladin
Postby Paladin » Sat Jan 18, 2020 10:54 pm
There appears to be an error in stdlib.h that prevents the ugfx_example from building:
from /esp/esp-iot-solution/submodule/esp-idf/components/nvs_flash/src/nvs_pagemanager.cpp:14:
/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/sys-include/stdlib.h:155:44: error: expected initializer before '__result_use_check'
 void *reallocarray(void *, size_t, size_t) __result_use_check __alloc_size(2)
/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/sys-include/stdlib.h:340:52: error: expected initializer before '__alloc_align'
 void * aligned_alloc(size_t, size_t) __malloc_like __alloc_align(1)
[156/653] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_api.cpp.obj
FAILED: nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_api.cpp.obj
In file included from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32 elf/include/c++/8.2.0/cstdlib:75,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/ext/string_conversions.h:41,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/bits/basic_string.h:6391,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/string:52,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/stdexcept:39,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/array:39,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/tuple:39,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/bits/unique_ptr.h:37,
                 from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/memory:80,
                 from /esp/esp-iot-solution/submodule/esp-idf/components/nvs_flash/src/nvs.hpp:18,
                 from /esp/esp-iot-solution/submodule/esp-idf/components/nvs_flash/src/nvs_api.cpp:14:
[158/653] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_storage.cpp.obj
FAILED: nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_storage.cpp.obj
In file included from /.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/cstdlib:75,
                 from/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/bits/unique_ptr.h:37,
                 from /esp/esp-iot-solution/submodule/esp-idf/components/nvs_flash/src/nvs_storage.hpp:17,
                 from /esp/esp-iot-solution/submodule/esp-idf/components/nvs_flash/src/nvs_storage.cpp:14:
[160/653] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_page.cpp.obj
ninja failed with exit code 1
pevsonic
Re: ugfx_example does not build with IDF 4.0
Postby pevsonic » Mon Feb 03, 2020 2:48 pm
Have you tried building with the 5.2.0 toolchain?
Paladin
Postby Paladin » Mon Feb 03, 2020 11:47 pm
No. How do I switch between toolchains?
