TTGO-T-display + SD card
froussel
Postby froussel » Thu Jan 02, 2020 7:18 pm
GGTO-T-diplay use SPI for screen (ESP32 + IPS ST7789V 1.14")
SCLK = 18, MISO = 19, MOSI = 23, SS = 5... (VSPI)
Can I use an other SPI for SD module ? HSPI ?
How ?
Re: TTGO-T-display + SD card
Postby Sprite » Fri Jan 03, 2020 3:33 am
Yes. The SPI pins of both user SPI peripherals are freely remappable.
froussel
Postby froussel » Fri Jan 03, 2020 9:10 pm
It is the first time that I have to use 2 SPI at the same time ...
I very often read that the ports are mappable on the esp32 but it is a very fuzzy concept for me ... Should we enter the libraries?
In addition not all ports are available on all ESP32 modules and most of the time they are never the same.
#include <TFT_eSPI.h>
#include <SPI.h>
#define TFT_MOSI            19
#define TFT_SCLK            18
#define TFT_CS                 5
#define TFT_DC               16
#define TFT_RST              23
#define TFT_BL                4
#include <SD.h>
SPIClass spiSD(HSPI);
#define SD_CS 13
#define SDSPEED 16000000
// Set SD Card SPI
 spiSD.begin(?,?,?,?);//SCK,MISO,MOSI,CS
 if(!SD.begin( SD_CS, spiSD, SDSPEED)){   // use only 12, 13, 14, 15 ou 25 26 if possible
   Serial.println("Card Mount Failed");
   return;
there is also http://www.iotsharing.com/2017/05/how-t ... dcard.html but as for the example above port 12 seems to cause problems during the upload
Postby Sprite » Mon Jan 06, 2020 1:15 am
From a technical PoV, the 'all ports are freely remappable' statement is exactly that: for most peripherals (UART, SD, I2C, I2S, ...) you can pick the GPIO the signals are routed from/to using the GPIO matrix. How that's implemented obviously depends. Also, not all ports make sense to map to: you don't want to repurpose your GPIOs that are connected to the internal flash, you can only use GPIO34 and higher as inputs, not outputs, and obviously if your board connects something else to the GPIO that you're routing to as well, that may interfere.
froussel
Postby froussel » Mon Jan 06, 2020 10:33 am
Test :
#include <SPI.h>
#include "WiFi.h"
#include <Wire.h>
#ifndef TFT_DISPOFF
#define TFT_DISPOFF 0x28
#endif
#ifndef TFT_SLPIN
#define TFT_SLPIN   0x10
#endif
#define TFT_MOSI            19
#define TFT_SCLK            18
#define TFT_CS              5
#define TFT_DC              16
#define TFT_RST             23
#define TFT_BL          4                      // Display backlight control pin
#define ADC_EN          14
#define ADC_PIN         34                     // prise du voltage
#define BUTTON_1        35
#define BUTTON_2        0
TFT_eSPI tft = TFT_eSPI(135, 240);             // Invoke custom library
Button2 btn1(BUTTON_1);                        // bouton de gauche
Button2 btn2(BUTTON_2);
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SD_CS 13
#define SDSPEED 27000000
ch
void setup()
    Serial.begin(115200);
    spiSD.begin(13,12,15,2);       //SCK,MISO,MOSI,ss
    {      Serial.println("Card Mount Failed");
           return;   }
insults at download
Arduino : 1.8.10 (Windows 10), Carte : "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
Le croquis utilise 730810 octets (55%) de l'espace de stockage de programmes. Le maximum est de 1310720 octets.
Les variables globales utilisent 40552 octets (12%) de mémoire dynamique, ce qui laisse 287128 octets pour les variables locales. Le maximum est de 327680 octets.
esptool.py v2.6
Serial port COM8
Connecting....
Chip is ESP32D0WDQ6 (revision 1)
MAC: 24:6f:28:25:4c:68
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
A fatal error occurred: Timed out waiting for packet content
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
is pin 12 the cause ?
I don't understand very well " Also, not all ports make sense to map to: you don't want to repurpose your GPIOs that are connected to the internal flash, you can only use GPIO34 and higher as inputs, not outputs"
Which pin to take for example ?
froussel
Postby froussel » Mon Jan 06, 2020 2:18 pm
With
pinMode(2, OUTPUT);
and
spiSD.begin(13,26,15,2);       //SCK,MISO,MOSI,ss
           return;   }
     else Serial.println("SD ok");
I have SD ok... :)
froussel
Postby froussel » Mon Jan 06, 2020 2:48 pm
If I add
File myFile;
 myFile = SD.open("test.txt", FILE_WRITE);
    // if the file opened okay, write to it:
    if (myFile)
    {   Serial.print("Writing to test.txt...");
        myFile.println("testing 1, 2, 3.");
        myFile.close();
        Serial.println("done.");   }
     else  Serial.println("error opening test.txt");
     myFile = SD.open("test.txt");
     if (myFile)
     {   Serial.println("test.txt:");
         while (myFile.available())
           {  Serial.write(myFile.read());      }
         myFile.close();       }
:evil:
SD ok
initialization done.
froussel
Postby froussel » Mon Jan 06, 2020 3:25 pm
All is OK if use the sample SD-test of library SD for esp32
dmitry.tereschenko
Postby dmitry.tereschenko » Mon Feb 17, 2020 7:03 pm
Hi! Can you help me, please, with sample code :)
I have the same board and trying to use SD card via HSPI - nothing works :(
Thanx in advance :)
froussel
Postby froussel » Tue Feb 18, 2020 8:20 am
My program is now well developed and extract that the part for the sd is complex.
It will be easier to correct your code
