Simple question: is it electrically safe to have the WROVER-KIT 4.1 board, being powered by an external 5V supply, while also connected to USB for JTAG debugging?
I have some other devboards that don't have an explicit jumper connection to select the 5V supply source, and at least one of them has a loud warning in the docs about not having 5V supply and USB connected at the same time. Needless to say with the device plugged into a system that is powering other devices (where USB supply current is insufficient) it has value to be able to accept the central power and also be able to debug.
Just looking for some clarity on this so I don't zap my WROVER-KIT or my laptop USB.
WROVER-KIT v4.1 5V-supply safety vs USB
Re: WROVER-KIT v4.1 5V-supply safety vs USB
According to the docs, its a either or selection via a jumper.
https://docs.espressif.com/projects/esp ... up-options
I understand the the PSU selection is by jumper. The question at hand is, once the board is jumpered for external 5V supply and powered up, is it safe to plug in the USB connection for flashing and JTAG access, or is there any risk of conflict with the supplies.
