Better ADC i/o accuracy ESP32 boards?
flaming_crossbow
Postby flaming_crossbow » Thu Feb 27, 2020 1:34 pm
I am a fanatic ESP32 mini user (MH ET LIVE or Wemos/Geekcreit D1 mini/WEMOS TTGO Mini D1 ESP32) because of its compact size.
But i am experiencing major issues with the huge tolerances on the ADC's accuracy. Analog sensor measurements are way too inaccurate for serious measurements. At 1.5 V the ADC input can register from 1.3 tot 1.6volt. This is a huge problem for temperature sensing etc etc.
Are there higher grade boards out there with the ESP32 chips that measure analog voltage very accurately ?
mikronauts
Re: Better ADC i/o accuracy ESP32 boards?
Postby mikronauts » Thu Feb 27, 2020 3:47 pm
Just use external adc.
Better esp32 adc will need a new esp32 version.
flaming_crossbow
Postby flaming_crossbow » Thu Feb 27, 2020 8:39 pm
Do you mean that it is a chip problem and not a pcb problem?
mikronauts
Postby mikronauts » Fri Feb 28, 2020 3:06 pm
unfortunately yes.
jgustavoam
Contact:
Postby jgustavoam » Sat Jun 20, 2020 2:48 am
My project is not compact, but very accurate and stable.
In fact, it uses one external DVM.
https://www.elektormagazine.com/labs/es ... -voltmeter
Retired IBM Brasil
