and the dongle is like this one
The signal TX0 on the module stay high (3.3V) while the RX0 seems to receive data. Are my connection in the schematic correct or I'm missing something?
According to thie official datasheet you do not need a reset button right ?your missing a button on the EN line to reset
Actually you dont need to do it, its enough to pull down IO0 and then connect to power supply.You do not need a "button" but when flashing you need a way to pull EN low. His schematic has no provision for doing that.
Sure, you can do it that way as well. But why bother when the EN and IO0 signals are built into the programming adapter. Just run the extra signal line. If your going to have a way to pull IO0 low, you might as well do the same for EN.Actually you dont need to do it, its enough to pull down IO0 and then connect to power supply.
