Memory leakage in IDF function
ukrsms
Postby ukrsms » Wed Jan 29, 2020 2:26 pm
During debugging of my own code I found two functions that don't deallocate all the memory they used.
Memory leaked only after the first used of the function
here are the fubctions:
memory leak 20 Bytes
ledc_fade_func_install(0);
ledc_fade_func_uninstall();
and
memory leak 84 Bytes:
esp_adc_cal_characteristics_t characters;
u8 calType=esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_11, ADC_WIDTH_BIT_12, 1100, &characters);
u32 voltage;
esp_adc_cal_get_voltage((adc_channel_t)1, &characters, &voltage);
Please, tell me whether I did something wrong, or it is a bug in IDF, or it is a normal operation of the functions?
Tested with IDF ver.4.1
ukrsms
Re: Memory leakage in IDF function
Postby ukrsms » Fri Feb 14, 2020 4:59 pm
after recent test I found one more function stealing memory:
esp_efuse_mac_get_default()
it steals 84 bytes after first calling
Postby Sprite » Sat Feb 15, 2020 10:04 am
Thanks for the report, however, you're probably better off creating a Github issue for this, as it will automatically get tracked into the system.
Angus
Postby Angus » Tue Feb 18, 2020 4:34 am
These may not be memory leaks as some types of data structures in IDF are allocated on first access ("lazy initialization") but are not deinitialized.
If you repeat the same init/deinit sequence multiple times, or call the same function multiple times, and the memory use goes up each time then this is definitely a memory leak.
If you need some tools to better analyze where allocations are happening, the heap tracing feature can help:
https://docs.espressif.com/projects/esp ... ap-tracing
Angus
ukrsms
Postby ukrsms » Thu Mar 05, 2020 10:09 am
Thank you, Angus
that are "lazy initialization", actually. However, it seems it is wrong behavior of the functions reported as IDF provided us with deinitialization function, however, not all memory is freed.
ukrsms
Postby ukrsms » Fri Mar 06, 2020 4:49 pm
One more "Lazy initialization" found. After executing the following sequence for the first time 204 bytes disappears
	TEST_ASSERT(nvs_flash_init_partition(PARTITION_LABEL_FACTORYDATA)==0);
	nvs_handle_t handle;
	TEST_ASSERT(nvs_open_from_partition(PARTITION_LABEL_FACTORYDATA, STORE_NAMESPACE_FACTORY, (nvs_open_mode_t)NVS_READWRITE, &handle)==0);
	nvs_close(handle);
	nvs_fl
ash_deinit_partition(PARTITION_LABEL_FACTORYDATA);
Angus
Postby Angus » Wed Mar 11, 2020 12:31 am
There is sometimes global intialization associated with the first time some functions is called. ledc_fade_func_install() registers an ISR internally, which involves some global initialization for the first time an ISR is allocated. Uninstalling and re-installing the same function (or a different ISR in another driver) shouldn't allocate this memory a second time.
Are these one-off small allocations causing a problem in your app?
ukrsms
Postby ukrsms » Thu Apr 16, 2020 7:28 am
No, it doesn't cause problems for the program. It just made me do spend time in order to decide whether I have memory leak in my program or not.
It would be easier if that information was documented (about "lazy initialization")
Users browsing this forum: Google [Bot] and 2 guests
