how to set BLE transmit power above 3dB?
ea2020
Postby ea2020 » Thu Mar 12, 2020 8:48 pm
I have my basic solution working (Adafruit ESP32 Feather to custom iOS application), but am not quite getting the range I want.
esp_bt.h enums the available esp_ble_power_type_t and esp_power_level_t to use when calling:
esp_ble_tx_power_set(esp_ble_power_type_t power_type, esp_power_level_t power_level)
These suggest that using ESP_PWR_LVL_P9 should result in a +9 dB transmit power rather than the +3 dB default.
BLEDevice.cpp shows that the BLEDevice::setPower method calls the above function and sets the default power (ESP_BLE_PWR_TYPE_DEFAULT) to whatever power level is passed in with the call.
I've tried calling BLEDevice::setPower in many places (immediately after my call to BLEDevice::init, in my server callbacks after a successful connection, etc.). But, I always end up with +3dB of transmit power according the the nRF connect app (range and RSSI values also remain unchanged).
Digging through the IDF documentation, I found the following function:
 esp_bredr_tx_power_set(esp_power_level_tmin_power_level, esp_power_level_tmax_power_level)
There is a note saying that it must be called after esp_bt_controller_enable and before anything that would cause the RF section to transmit.
Since esp_bt_controller_enable is called in BLEDevice::init, I tried the following:
BLEDevice::init()
esp_bredr_tx_power_set(ESP_PWR_LVL_N12, ESP_PWR_LVL_P9)
BLEDevice::setPower(ESP_PWR_LVL_P9).
I still only see +3 dB transmit power.
I cannot find a call to esp_bredr_tx_power_set anywhere within the arduino IDE BLE source files (1.0.4/libraries/BLE/src), so I do not know where the default esp_power_level_tmax_power_level is being set.
Does anyone have any suggestions of what I am doing wrong?
If not, can anyone tell me where the +3 dB default value is set so I could at least hack something ugly together to test with +9 dB?
GYC-Espressif
Re: how to set BLE transmit power above 3dB?
Postby GYC-Espressif » Fri Mar 13, 2020 1:08 pm
Hello. This function is provided by ESP-IDF. And you can use it in following ways.
Code: Untitled.c Select all
* @brief Set BLE TX power
* Connection Tx power should only be set after connection created.
* @param power_type : The type of which tx power, could set Advertising/Connection/Default and etc
* @param power_level: Power level(index) corresponding to absolute value(dbm)
* @return ESP_OK - success, other - failed
esp_err_t esp_ble_tx_power_set(esp_ble_power_type_t power_type, esp_power_level_t power_level);
To set the 9dB tx Power for adv, you can set it as
esp_ble_tx_power_set(ESP_BLE_PWR_TYPE_ADV,ESP_PWR_LVL_P9);
Thanks.
chuledeco
Postby chuledeco » Fri Mar 28, 2025 4:50 pm
I have the same problem. It doesn't matter if I change the power using:
The Tx power remains +3dbm
I'm reading the Tx power using NrfConnect
lbernstone
Postby lbernstone » Fri Mar 28, 2025 9:06 pm
The timing matters
Try setting the defaults and actually look at the result to make sure it is ESP_OK (not all devices have the same power capabiities)
esp_err_t result = esp_ble_tx_power_set(ESP_BLE_PWR_TYPE_DEFAULT,ESP_PWR_LVL_P9);
