Advice using FFT on the ESP32 - ESP-DSP Component
o.copleston
Contact:
Postby o.copleston » Fri Aug 09, 2019 8:51 pm
I have been developing a sound visualisation project using the FFT function from the ESP-DSP component. Audio is captured using an INMP441 which is then passed to the FFT function.
I am getting great data for higher frequencies but low frequency input cause a bunch of unwanted data to appear at higher frequencies.
The above image is my FFT's output for an input frequency of 125Hz
I've tried a Hanning window before and after the FTT but the issue still persists.
I've really been struggling with the ESP-DSPs lack of documentation, does anybody have experience that could share some advice?
Developer at SquidSoup
Person on Twitter | Instagram
drewandre
Re: Advice using FFT on the ESP32 - ESP-DSP Component
Postby drewandre » Mon Mar 16, 2020 11:35 pm
Could you share any code samples? Tough to tell without seeing any examples.
krzychb
Contact:
Postby krzychb » Tue Mar 17, 2020 8:24 am
Hi o.copleston,
I assume you have already checked ESP-DSP documentation under https://docs.espressif.com/projects/esp ... index.html
If so, please comment how to improve it :idea:
Dmitry01
Postby Dmitry01 » Tue Mar 17, 2020 1:12 pm
Hi o.copleston,
I assume that you forgot to use bit reverse operation after the FFT.
Your code should look like this:
    for (int i=0 ; i< N ; i++)
        y_cf[i*2 + 0] = your_signal_samples[i] * wind[i];
        y_cf[i*2 + 1] = 0;
    dsps_fft2r_fc32(y_cf, N);
    dsps_bit_rev_fc32(y_cf, N); // <================= Bit reverce
    dsps_cplx2reC_fc32(y_cf, N);// <=============== Complex spectrum in y_cf
Here you have the complex spectrum in y_cf.
Regards,
Dmitry
oswe23
Postby oswe23 » Thu Mar 26, 2026 11:06 am
hello, im also testing.
what id like to know is the equations used. are they Cooley Tukey ? there´s no mention also on the window Hann algorithm.
im running simple examples trying to get the exact values of the coeficients but always some digits are different so im blind, i dont know which is the math that is implemented...
Users browsing this forum: Qwantbot, Semrush [Bot] and 2 guests
