Audio board init with ESP32-WROVER_IB (16MB)
Ismael
Postby Ismael » Fri Mar 20, 2020 11:38 am
Hello
In our project board we've using module ESP32-WROVER-IB with 16MB of Flash. To reproduce audio our board has the same esquema of the LyraT_v4.3 with some pins changes.
The issue is that the MP3 simple example works perfect buf when I tried to enable external SPI RAM (default conf), it doesn't work.
To add more information, configuration file is attached and the pin changes of our custom board are:
	HEADPHONE_DETCET          GPIO_NUM_16
        PA_ENABLE_GPIO            GPIO_NUM_17
	i2c_config->sda_io_num = GPIO_NUM_32;
        i2c_config->scl_io_num = GPIO_NUM_33;
	i2s_config->bck_io_num = GPIO_NUM_5;
        i2s_config->ws_io_num = GPIO_NUM_25;
        i2s_config->data_out_num = GPIO_NUM_26;
        i2s_config->data_in_num = GPIO_NUM_35;
And in i2s_mclk_gpio_select function gpio_num is forced to: gpio_num = GPIO_NUM_1;
Here is the trace of the problem:
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6980
load:0x40078000,len:12072
load:0x40080400,len:6908
entry 0x4008079c
I (72) boot: Chip Revision: 1
I (72) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot: ESP-IDF v3.3.1-211-g6f9a7264c 2nd stage bootloader
I (39) boot: compile time 12:26:57
I (40) boot: Enabling RNG early entropy source...
I (44) boot: SPI Speed      : 40MHz
I (48) boot: SPI Mode       : DIO
I (52) boot: SPI Flash Size : 16MB
I (57) boot: Partition Table:
I (60) boot: ## Label            Usage          Type ST Offset   Length
I (67) boot:  0 nvs              WiFi data        01 02 00009000 00004000
I (75) boot:  1 otadata          OTA data         01 00 0000d000 00002000
I (82) boot:  2 phy_init         RF data          01 01 0000f000 00001000
I (90) boot:  3 factory          factory app      00 00 00010000 00200000
I (97) boot: End of partition table
I (101) boot: Defaulting to factory image
I (106) boot_comm: chip revision: 1, min. application chip revision: 0
I (113) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2c254 (18
0820) map
I (186) esp_image: segment 1: paddr=0x0003c27c vaddr=0x3ffb0000 size=0x020ac (
8364) load
I (189) esp_image: segment 2: paddr=0x0003e330 vaddr=0x40080000 size=0x00400 (
1024) load
I (193) esp_image: segment 3: paddr=0x0003e738 vaddr=0x40080400 size=0x018d8 (
6360) load
I (204) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0x2a32c (17
2844) map
I (271) esp_image: segment 5: paddr=0x0006a34c vaddr=0x40081cd8 size=0x0d910 ( 5
5568) load
I (303) boot: Loaded app from partition at offset 0x10000
I (303) boot: Disabling RNG early entropy source...
I (304) psram: This chip is ESP32-D0WD
I (310) spiram: Found 64MBit SPI RAM device
I (313) spiram: SPI RAM mode: flash 40m sram 40m
I (318) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (326) cpu_start: Pro cpu up.
I (329) cpu_start: Application information:
I (334) cpu_start: Project name:     play_mp3
I (339) cpu_start: App version:      v2.0-beta3-25-g11b626c-dirty
I (346) cpu_start: Compile time:     Mar 20 2020 12:27:01
I (352) cpu_start: ELF file SHA256:  030bab1bcf69d565...
I (358) cpu_start: ESP-IDF:          v3.3.1-211-g6f9a7264c
I (364) cpu_start: Starting app cpu, entry point is 0x40081480
I (351) cpu_start: App cpu up.
I (1255) spiram: SPI SRAM memory test OK
I (1256) heap_init: Initializing. RAM available for dynamic allocation:
I (1256) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1262) heap_init: At 3FFB31A8 len 0002CE58 (179 KiB): DRAM
I (1268) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1275) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1281) heap_init: At 4008F5E8 len 00010A18 (66 KiB): IRAM
I (1288) cpu_start: Pro cpu start user code
I (1293) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (307) cpu_start: Starting scheduler on PRO CPU.
I (309) spiram: Reserving pool of 32K of internal memory for DMA/internal alloca
tions
I (309) PLAY_MP3_FLASH: [ 1 ] Start audio codec chip
I (339) PLAY_MP3_FLASH: [ 2 ] Create audio pipeline, add all elements to pipelin
e, and subscribe pipeline event
I (339) PLAY_MP3_FLASH: [2.1] Create mp3 decoder to decode mp3 file and set cust
om read callback
I (349) PLAY_MP3_FLASH: [2.2] Create i2s stream to write data to codec chip
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandle
d.
Core 0 register dump:
PC      : 0x4008efdf  PS      : 0x00060730  A0      : 0x80084df8  A1      : 0x3f
fb4c30
A2      : 0x3f800000  A3      : 0x000000d0  A4      : 0x00000000  A5      : 0x00
070c80
A6      : 0x00000102  A7      : 0x00000000  A8      : 0x00000000  A9      : 0xff
ffffff
A10     : 0x3f800010  A11     : 0x00060b23  A12     : 0x3f800014  A13     : 0x00
000000
A14     : 0xffffffff  A15     : 0x00000000  SAR     : 0x00000014  EXCCAUSE: 0x00
00001c
EXCVADDR: 0xffffffff  LBEG    : 0x400029ac  LEND    : 0x400029cb  LCOUNT  : 0x00
000000
ELF file SHA256: 030bab1bcf69d565fb644b99ef2d079b4719c4fe72ca85eb1e50b1d08e9faa6
c
Backtrace: 0x4008efdf:0x3ffb4c30 0x40084df5:0x3ffb4c50 0x400ea3a4:0x3ffb4c70 0x4
00e9215:0x3ffb4c90 0x400eaa24:0x3ffb4d20 0x400d64b6:0x3ffb4de0 0x400d17e4:0x3ffb
4ef0 0x4008c1b1:0x3ffb4f10
Rebooting...
Thanks so much.
sdkconfig.txt
(22.7 KiB) Downloaded 595 times
Re: Audio board init with ESP32-WROVER_IB (16MB)
Postby Sprite » Sun Mar 22, 2020 12:11 pm
Hard to say, but it would probably help if you could decode that register dump.
Ismael
Postby Ismael » Mon Mar 23, 2020 8:48 am
Hello ESP_Sprite,
Thanks for your reply.
I'm trying to get the translations of those registers but I'm having some problems with openocd + xtensa over eclipse debugging.
The code that is running is the examples/get-started/play_mp3 with the only modification of the SRAM enabled.
In case I achieve your request, I will it write back.
Thanks so much.
Ismael
Postby Ismael » Mon Mar 23, 2020 10:38 am
Hello again,
After analyzing the map file and the call backtrace, the program reset in function: multi_heap_malloc_impl.
Program trace is:
multi_heap_malloc_impl -> heap_caps_malloc -> audio_calloc -> audio_element_init -> i2s_stream_init -> app_main
Thanks so much.
Postby Sprite » Mon Mar 23, 2020 6:26 pm
Ah, I missed the smoking gun the first time:
Apart from your creative spelling of the word 'detect', the problem with this code is that GPIO16 and 17 are used by the PSRAM, and re-using them as something else will lead to issues like you have seen.
Ismael
Postby Ismael » Tue Mar 24, 2020 8:54 am
Thanks so much ESP_Sprite for the answer. It solve my problem.
Have a nice day.
