Memory allocation problem WroverB ADF
profDev
Postby profDev » Fri Apr 17, 2020 5:37 am
I'm writing an application in ESP-ADF.
My board is TTGO Wrover B connected via ESP Prog.
All works well till yesterday, and i am not able to getting it working again.
In Initialisation there seems to be a memory Problem. audio_pipeline_init runs in the "memory exhaust" error:
player->pipeline = audio_pipeline_init(&pipeline_cfg);
	if (player->pipeline == NULL)
		ESP_LOGE(TAG, "Error creating audio Pipeline");
		return NULL ;
Debugger says that it should allocate the Memory with this code in audio_mem.c, nmemb=1 and size = 32
 data = heap_caps_malloc(nmemb * size, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
I do not know, if it has something to do with:
Programming without Jtag over serial with make Flash has also error, also with ALL devices DISCONNECTED
App "play_and_save" version: 1
Flashing binaries to serial port /dev/ttyUSB0 (app at offset 0x10000)...
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32D0WDQ5 (revision 1)
Crystal is 40MHz
MAC: b4:e6:2d:de:90:19
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
A fatal error occurred: Timed out waiting for packet header
make size shows:
Total sizes:
 DRAM .data size:   14016 bytes
 DRAM .bss  size:   25680 bytes
Used static DRAM:   39696 bytes ( 141040 available, 22.0% used)
Used static IRAM:   98025 bytes (  33047 available, 74.8% used)
      Flash code:  630501 bytes
    Flash rodata:  164904 bytes
Total image size:~ 907446 bytes (.bin may be padded larger)
Pleas help me finding a solution for this Problem.
