How do i add esp-adf path
Embel.Tech
Postby Embel.Tech » Thu May 07, 2020 12:11 pm
Hello Forum,
I have installed esp-idf through command line, the required version is 3.3.1.
I am using win 10 OS.
Still not able to understand the way to add path of esp-adf according to https://docs.espressif.com/projects/esp ... ofile.html this document.
In https://docs.espressif.com/projects/esp ... ut-esp-adf this document, it says that add path of esp-adf same as you added path of esp-idf. but there is no intall.bat and export.bat file present in esp-adf.
Please help me out.
Thank you.
