ESP-WROOM with MPU6050 design
adesandr
Postby adesandr » Tue May 12, 2020 5:30 pm
I have developed a design with an ESP-WROOM-32 and a MPU6050 products and I attached the schematic in the attachment
ESP_MAD_RevE.pdf
(45.17 KiB) Downloaded 625 times
The design is based on the esp32 adafruit feather schematic, with the introduction of one SPDT switch to power on/off the board and the interface with an MPU6050.
All your comments will be appreciated.
Thank you in advance for your help.
Regards.
MCUism
Re: ESP-WROOM with MPU6050 design
Postby MCUism » Tue May 12, 2020 11:32 pm
I have developed a design with an ESP-WROOM-32 and a MPU6050 products and I attached the schematic in the attachment ESP_MAD_RevE.pdf.
Regards.
Looks great and neat to me.
adesandr
Postby adesandr » Wed May 13, 2020 6:20 pm
Thanks for your reply.
admaxtv
Postby admaxtv » Thu May 12, 2022 7:46 pm
I have tried all headers in the MPU6050 library. I have no compilation errors UNTIL I try to use any class references to the MPU6050.
  mpu.Initialize();
Presents no errors but the code simply does not operate.
I can add a line of code below it
Serial.print("Hey this is working!")
but it will never appear on the serial monitor...because the program freezes at mpu.initialize().
I've tried various headers such as MPU6050_6Axis_MotionApps20.h and all other listed in the folder.
All will fail without warning.
I know that the devices are connected together properly because I can use the wire.h library to call the stream with success.
I want to use the MPU6050 class and functions so that I can loop through and address multiple gyroscopes. The library I found that is working (so far) is the TinyMPU6050.
Just a little FYI. If other code works but not the MPU6050 library, then its the library...not you.
admaxtv
Postby admaxtv » Thu May 12, 2022 11:16 pm
None of the MPU6050 library functions work. They will compile without error but when you call anything in the class it will crash. For instance mpu.initiate() will crash the program.
I have found that TinyMPU6050 will work, but with limited functionality (ergo "Tiny").
