Hello people...
I want to use ESP32, to shoot if it "sees" any movement.
HOWEVER, I want to put Presence Sensor too, so I wanted to know if you have a microcontroller, cheaper than ESP32, because I don't need so much processing. In reality the most problem is the cost, the dollar, it's complicated.
Researching I discovered a Wemos D1 Mini; but does anyone know any other microcontrollers that i can connect a motion sensor to? It should go through WI-FI, or Bluetooth, to the cell phone warning that someone has.
Thank you.
Microcontroller simpler than ESP32
julianorodrigues0316
Re: Microcontroller simpler than ESP32
You can try to go lower than that, but it may be hard:
https://www.digikey.pl/product-detail/e ... D/11613155
Users browsing this forum: Baidu [Spider], Barkrowler and 3 guests
