Reading Certificates from Spiffs partition on the flash memory of esp32
saransh.goel
Postby saransh.goel » Wed May 27, 2020 6:45 am
I am able to flash the certificates on siffs partition and access the certificates using file handling but how do i load then for SSL server certification and esp_http_client_config_t.
I was previously embedding the certificates into the firmware using the components.mk file like this
COMPONENT_EMBED_TXTFILES = device_cert.pem
and then using them like this
extern const uint8_t device_cert_pem_start[]   asm("_binary_device_cert_pem_start");
extern const uint8_t device_cert_pem_end[]   asm("_binary_device_cert__pem_end");
But I don't know how to load them from the spiffs partition in the flash memory. Can somebody please help me out ?
Saransh Goel
RMandR
Re: Reading Certificates from Spiffs partition on the flash memory of esp32
Postby RMandR » Thu May 28, 2020 8:50 pm
@saransh.goel
Have a look at this post. I asked for a similar purpose:
https://esp32.com/viewtopic.php?f=13&t=12963
In my case, I ended up copying the certificate data into RAM and passing them to the APIs.
It looks like you may have to do the same:
https://docs.espressif.com/projects/esp ... _config__t
Users browsing this forum: Bytespider, PerplexityBot and 1 guest
