您好!初次接触ESP32,准备用ESP32-LyraT做一些东西,在编译ESP-ADF例程的时候遇到以下问题,希望各位大佬能够帮助解决,非常感谢!
icantean@DESKTOP-VANR688 MINGW32 /c/ESP32/esp-adf-2.0-beta2/examples/get-started/play_mp3
$ make all
fatal: 不是一个 git 仓库(或者任何父目录):.git
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
Python requirements from C:/ESP32/esp-idf-v3.3.1/requirements.txt are satisfied.
Project is not inside a git repository, will not use 'git describe' to determine PROJECT_VER.
App "play_mp3" version: 1
CC build/audio_stream/algorithm_stream.o
C:/ESP32/esp-adf-2.0-beta2/components/audio_stream/algorithm_stream.c:31:21: fatal error: esp_aec.h: No such file or directory
compilation terminated.
make[1]: *** [/c/ESP32/esp-idf-v3.3.1/make/component_wrapper.mk:290:algorithm_stream.o] 错误 1
make: *** [C:/ESP32/esp-idf-v3.3.1/make/project.mk:552:component-audio_stream-build] 错误 2
编译ESP-ADF例程play_mp3出错找不到esp_aec.h头文件
