change the name of the device in STA mode
brp80000
Postby brp80000 » Wed Jan 30, 2019 12:23 am
How can I change the device name in STA mode. I see the name "espressif" now.
chillophil
Re: change the name of the device in STA mode
Postby chillophil » Wed Jan 30, 2019 2:13 am
Hey,
it's not quite clear what your screenshot is showing and I don't know the exact issue. I guess it's showing physical devices currently connected to your AP?
In that case, the shown device names probably rather identify your devices manufacturers (by MAC address OUI) than hostnames and you won't be able to change that. MAC addresses starting with OUI (organizationally unique identifier) 30:A8:DB are owned by Sony, those starting with OUI 30:AE:A4 are owned by Espressif - you can easily look that up for your own if you want to.
But if it shows hostnames (by DHCP), maybe give
tcpip_adapter_set_hostname(...)
esp_err_t tcpip_adapter_set_hostname(tcpip_adapter_if_t tcpip_if, const char *hostname);
a try
brp80000
Postby brp80000 » Thu Jan 31, 2019 5:51 am
its don`t work
ESP_ERROR_CHECK(tcpip_adapter_set_hostname(TCPIP_ADAPTER_IF_STA, "ULA"));
device name still "Espressif "
Postby Sprite » Thu Jan 31, 2019 7:18 am
Sounds like the thing shows the owner of the MAC address (the default hostname for Espressif devices is ESP-xxxx, not Espressif). No way to change that, apart from perhaps getting your own OUI from the IEEE so you can give out your own MAC addresses...
brp80000
Postby brp80000 » Thu Jan 31, 2019 8:07 am
How to change?
Postby Sprite » Fri Feb 01, 2019 2:52 am
Hmm, seems it's indeed not MAC-related. In that case, tcpip_adapter_set_hostname should change the id. No idea what else the name could come from, perhaps you can ask your router manufacturer?
jiapei100
Postby jiapei100 » Fri Aug 23, 2019 8:42 pm
Same question here... I actually tried to connect multiple esp32-cams with the router, but EVERY unit is named as espressif, which seems to be problematic:
The FIRST device connected in will block the rest with the Destination Host Unreachable message.
What's your symptom?
And have you solved this by rename the device name ? For instance:
  • expressif1
  • espressif2
  • espressif3
  • etc.
Longer Vision Technology
Rainwater
Postby Rainwater » Sat Jun 13, 2020 5:01 pm
Have you tried changing the `Local netif hostname` in the `menuconfig` option?
"idf.py menuconfig"
Found in the "Component config" -> "LWIP"
some esp dev guy
Postby some esp dev guy » Sun Sep 01, 2024 3:12 pm
after
esp_netif_init();
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
you can change hostname
esp_netif_set_hostname(sta_netif, "my tiny daemon");
Users browsing this forum: Amazon [Bot], Barkrowler, ChatGPT-User, Google [Bot], Qwantbot and 1 guest
