Segger J-Link fails to halt the esp32.cpu1
bobik78
Postby bobik78 » Tue Mar 07, 2017 5:20 am
Hello All,
I have ESP32 dev. board with Segger j-link as JTAG debugger.
I tried to debug ESP32 sample applications with use of OpenOCD and GDB but it failed due to "TARGET: esp32.cpui1 - Not halted" error.
 ./src/openocd -s ./tcl -f ./esp32.cfg
Open On-Chip Debugger 0.10.0-dev-g90071eb (2017-03-06-11:53)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 200 kHz
force hard breakpoints
Info : No device selected, using first device.
Info : J-Link V9 compiled Apr 22 2016 11:47:06
Info : Hardware version: 9.30
Info : VTarget = 3.316 V
Info : clock speed 200 kHz
Info : esp32.cpu0: Target halted, pc=0x40000400
Info : Auto-detected RTOS: FreeRTOS
Info : esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F).
esp32.cpu0: target state: halted
Error: timed out while waiting for target halted
TARGET: esp32.cpu1 - Not halted
in procedure 'reset'
in procedure 'ocd_bouncer'
Did anyone encountered similar problem and solved it?
Any help/explanation - appreciated :)
Thanks,
Baruch
BuddyCasino
Re: Segger J-Link fails to halt the esp32.cpu1
Postby BuddyCasino » Tue Mar 07, 2017 8:27 am
Similar for me - I have to run the debugger shortly after powering up the board, its a narrow time window.
bobik78
Postby bobik78 » Wed Mar 08, 2017 10:24 pm
This didn't work for me.
Any idea what's a problem? Is it a debugger issue or ESP32 issue?
Anyone knows?
BTW, According to ESP32 documentation -
Hardware-wise, when one CPU is halted because of debugging reasons, the other one will be halted as well; resuming also happens simultaneously.
Thanks.
