About the CAN controller.
Re: About the CAN controller.
Are you using WROVER or WROOM/DEV KITC?
WROVER have most of pins pulled up, it doesn't work then.
thomas,I also use the MCP2551.
An example is planned but currently im drowning in work...
have tested it just in time here with MCP2551 too ( before with TJA1051 )
works like a charme too.
now we go next steps..
..But nothing is betrayed or chattered -
The esp guys betray or whisper us also nothing to the sound (i2s)..
rudi
fast test,No problem! I was able to get this workingI also use the MCP2551.
An example is planned but currently im drowning in work...The code provided was perfect - I just needed to wire up my MCP2551 correctly.
perhabs this helps:
https://twitter.com/eMbeddedHome/status ... 2771785728
rudi
hi
ESPCan driver as component and menuconfig ready for PullRequest to ESP-IDF components
comes asap
rudi
comes asap
rudi
hi jeroenNice! Thank you very much. I'll see if we can integrate it into esp-idf.
CAN Driver base ready
CAN Driver menuconfig ready
do you have start integrate work?
if not we do this PR to github or Third party IDF components list
what is the best`?
please do not underestimate the subject "CAN"
it is a very popular subject at a distance
thank you
rudi
Looking good.
How many CAN messages are you able to send or receive per second?
Cheers
Cheers
hiLooking good.
Cheers
here in a 125kbit test with allways 8 byte difference data
i use standard msg and is
1+11+1+1+1+4+64+15+1+1+1+7 = 108 bit long
interframe spacing perhabs 3 do 6
so
+ six bits interframe spacing
caculation of this i think would be:
125000 / ( 108 + 6 ) = 1096 frames ( CAN messages ) per second.
this is theoretically,
practial in code there are small delays between the messages ( 20-50ms ) ,
CAN uses NRZ coding, and in this example i not calculated ACK and other few things ,
perhabs 900 frames/sec i think are possible, perhabs will check this by time in a test dialog later for using with higher rate too
check this answere here too
rudi
I know the theoretical throughput
At 1MBit you should be able to push out a little less than 8000 frames per second.
Did you really see 20 - 50 ms between frames, or are these µs?
Still a lot, considering a fast frame is only a bit more than 100µs...
Cheers
Hans
Cheers
Hans
