Serial0 message
GlenBK4KV
Serial0 message
Postby GlenBK4KV » Fri Aug 28, 2020 10:43 am
The project I am compiling and running is huge, about 20,000 lines. It compiles to 280k of flash.
It uses Serial0 for its control port. The control port works, but every once in a while I see
a message from the ESP32, something about the stack getting 'smashed' and the board resets,
all of this over Serial0.
I am not sure why this is happening, and what to do about it.
Obviously, I cannot have the board reset randomly!
TIA
GlenB
Re: Serial0 message
Postby Sprite » Sat Aug 29, 2020 7:52 am
Well, if anything it would help a lot if you could post the exact message you get...
chegewara
Re: Serial0 message
Postby chegewara » Mon Aug 31, 2020 9:54 am
You need to increase task stack.
