(solved) connecting to Wifi using static IP
mzimmers
Postby mzimmers » Sat Sep 05, 2020 4:01 am
Hi all -
I'm trying to get a ESP32 with a fixed IP address to connect to an access point. I'm getting an error "Host is unreachable."
My calls to esp_wifi_start and esp_wifi_connect seem to be returning successfully. Is there anything special I need to do? I didn't see anything in the wifi_init_config_t struct that I need to change, but maybe I'm missing something.
Thanks for any help...
opcode_x64
Re: conntecting to Wifi using static IP
Postby opcode_x64 » Sat Sep 05, 2020 9:18 pm
Hey,
without seeing any code:
As far as I know and understand the WiFi driver is independent from the TCP/IP layer, meaning connecting to an access point has nothing to do with TCP/IP at first. After your connection is established, then your access point is assigning your device (ESP32) an IP address if DHCP is enabled on the access point. Did you check your access point settings ? Are the "static" TCP/IP configurations such IP, Gateway etc.. are configured proper on your ESP32 and are they compliant with the access point ?
Good luck !
opcode_x64
tommeyers
Re: connecting to Wifi using static IP
Postby tommeyers » Sun Sep 06, 2020 3:20 pm
I have a recollection of a wifi lig that can be activated. I tried to find that - no luck.
That log, if it exists, might give more clues.
Tom
IT Professional, Maker
Santiago, Dominican Republic
tommeyers
Postby tommeyers » Sun Sep 06, 2020 3:23 pm
Here it is:
https://docs.espressif.com/projects/esp ... m/log.html
Tom
mzimmers
Postby mzimmers » Mon Sep 07, 2020 3:13 pm
Thanks for the replies, guys. I already get wifi log messages, and there's nothing helpful in there.
I'll look at my AP more closely to see whether it restricts static IP addresses, though that seems unlikely.
mzimmers
Postby mzimmers » Wed Sep 09, 2020 1:45 pm
So, here's what was missing:
tcpip_adapter_ip_info_t m_ipInfo = { {0}, {0}, {0} };
if (m_tasks->flash->get(NVS_KEY_IPSOURCE) == IP_SOURCE_TXT[IP_SOURCE_STATIC])
	ESP_ERROR_CHECK(tcpip_adapter_dhcpc_stop(TCPIP_ADAPTER_IF_STA));
	// extract elements, convert to string and pass to NVS.
	s.assign(m_tasks->flash->get(NVS_KEY_IPADDR));
	inet_pton(AF_INET, s.c_str(), &(m_ipInfo.ip.addr));
	s.assign(m_tasks->flash->get(NVS_KEY_IPGATEWAY));
	inet_pton(AF_INET,  s.c_str(), &(m_ipInfo.gw.addr));
	s.assign(m_tasks->flash->get(NVS_KEY_IPSUBNET));
	inet_pton(AF_INET,  s.c_str(), &(m_ipInfo.netmask.addr));
	ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_STA, &m_ipInfo));
In short, the calls to tcpip_adapter_dhcpc_stop() and tcpip_adapter_set_ip_info() were what was missing. Note: this is a solution for esp-idf v4.0.1. V4.1 deprecates tcpip_adapter in favor of netif.
Users browsing this forum: Google [Bot], PerplexityBot and 1 guest
