FAT FS Maximum number of files
Wootsies
Postby Wootsies » Sat Sep 19, 2020 7:08 am
Hi everyone I am pretty new to the ESP32 and I have been experimenting with a persistent storage mechanism.
Because I intend to use flash encryption eventually, I have been testing a FAT file system although at this stage I have not actually turned it on in the compile options. While using the example for wear leveling in ESP IDF, I tried to create 600 files and met an issue where I cant seem to create more than 512 files. Does anyone know what is the cause for this? When I return the errno value I get an error of -2 and I cant tell what exactly it means. When I check the space left in the FAT using f_getfree I find that I still have space remaining so it is not because I have run out of space s I have set the partition as 1MB.
Any help to point me in the right direction would be appreciated.
Thanks in advance!
I set my
 CONFIG_WL_SECTOR_SIZE = 512
in the wear leveling options of idf menu
Code snippet:
    static wl_handle_t s_wl_handle = WL_INVALID_HANDLE;
    esp_err_t err;
    char *basePath = "/spiflash";
    char *logFilePath = "/spiflash/";
    FILE *f;
    const esp_vfs_fat_mount_config_t mount_config = {
        .max_files = 4,
        .format_if_mount_failed = true,
        .allocation_unit_size = CONFIG_WL_SECTOR_SIZE};
    err = esp_vfs_fat_spiflash_mount(basePath, "storage", &mount_config, &s_wl_handle);
    char filepath[27] = "";
    char str[12];           // Index
    for (int k = 0; k < 600; k++)
        filepath[0] = '\0';
        sprintf(str, "%d", k);              // convert int to char
        strncat(filepath, logFilePath, 14); // Put Base path
        strncat(filepath, str, 12);         // Add index
        ESP_LOGI(TAG, "Get Entry FilePath: %s", filepath);
        f = fopen(filepath, "w");
        if (f == NULL)
            ESP_LOGE(TAG, "Failed to open file for writing error: %d", errno);
            return;
        else
            if (fprintf(f, "%s", "helloWorld") == EOF)
                ESP_LOGE(TAG, "ERROR RETURNED, Memory Might be full");
            fclose(f);
        fclose(f);
    esp_vfs_fat_spiflash_unmount(basePath, s_wl_handle);
Partition:
# Name,   Type, SubType, Offset,  Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs,      data, nvs,     0x9000,  0x6000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  app,  factory, 0x10000, 1M,
storage,  data, fat,     ,        1M, encrypted
Re: FAT FS Maximum number of files
Postby Sprite » Sun Sep 20, 2020 7:40 am
Did you create these files in the root folder of the FAT partition? If I recall correctly, one of the quirks of FAT (in general, so not only the ESP32 implementation) is that it only allows a limited amount of files in the root folder. Non-root folders do not have that limitation.
chegewara
Postby chegewara » Sun Sep 20, 2020 12:29 pm
There is 2 problems you have:
- like @ESP_Sprite mentioned, FAT root folder has limited number of entries (folders and files),
- this is bigger problem: each single file is using at least 1 cluster and if cluster size is 4096 bytes, then you are limited to about 256 files on 1MB partition; since you have sector/cluster size 512 your limitation will be about 1000 files.
Since we dont know files size and this is only theoretically calculation, you may encounter any of those issues.
Wootsies
Postby Wootsies » Sun Sep 20, 2020 3:47 pm
Thanks for the response everyone.
You were precisely right, it seems that the limit on the root directory is 512. Once I created a sub-directory, I was not limited anymore.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot], Qwantbot, Semrush [Bot] and 2 guests
