Hello!!!
I'm trying to reduce esp32 cpu frequency in order to lower power consumption. If PLL Clock Source from internal oscillator is used I can reduce CPU frequency till 80 MHz, with freeRTOS support and project configuration found in menuconfig options. However, I want to use the 40 MHz On-Chip Crystal as my clock source (I'm using ESP32-WROOM32 chip) to reduce CPU frequency even more than I've already have. I tried soc/rtc.h API functions (ex: rtc_clk_cpu_freq_set_config), but the API itself recommends not to use these functions due to other clocks and timers that should be reconfigured according to the new CPU frequency and this issue is not implemented by the API, so the correct working of freeRTOS programs using these functions is not guaranteed. I ignored the recommendation and used the API, and suddenly I started getting incorrect data from serial communication which I see in my serial monitor. Can someone from Espressifs or someone who has already dealt with this comment on this issue as this is not deeply treated in esp-idf documentation? Is there any other way to reduce CPU frequency?
Thanks in advance
Regards
CPU Clock source and frequency
Return to “General Discussion”
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
