ESP32 NVS Configuration at Flash
BrettG
Postby BrettG » Thu Mar 16, 2017 9:02 pm
Hi, is it possible while flashing a device to also flash on NVS data onto the NVS? Currenly every time I flash a device the NVS is being cleared. Instead I would like to add configuration data etc. Is there any too similar to "make partition_table-flash", where I can setup the key-value pairs for the NVS to be loaded on when flashed?
Thanks,
- Brett
BrettG
Re: ESP32 NVS Configuration at Flash
Postby BrettG » Fri Mar 17, 2017 8:54 pm
After a bit more digging I found the embedding binary data section in the docs where I was able to add all my data in as a json structured string. This seems to be the best solution I can find at the moment.
Users browsing this forum: Bytespider, ChatGPT-User and 3 guests
