please help to get JTAG working on esp wrover kit
imtiaz
Postby imtiaz » Tue Mar 14, 2017 8:40 pm
Hi All,
I have followed the instructions to get JTAG working on the esp wrover kit on a virtual linux machine. when I invoke the following command :
./src/openocd -s ./tcl -f ./esp32.cfg
I get the following response:
Error : no device found
Error : unable to open ftdi device with vid 0403, pid8a98 , description '*' , serial '*' at bus location '*'
Error : libusb_open() failed eith LIBUDB_ERROR_ACCESS
Please help
Imtiaz
imtiaz
Re: please help to get JTAG working on esp wrover kit
Postby imtiaz » Tue Mar 14, 2017 10:15 pm
got a bit further :
Open On-Chip Debugger 0.10.0-dev-g90071eb (2017-03-15-07:48)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 200 kHz
force hard breakpoints
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 8a98, description '*', serial '*' at bus location '*'
Info : clock speed 200 kHz
Info : esp32.cpu0: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu0: Core was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu1: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu1: Core was reset (pwrstat=0xFF, after clear 0xFF).
Postby Sprite » Thu Mar 16, 2017 4:25 am
The esp-wrover kit needs jumpers on all but the outer two positions of the header closest to the reset button for jtag to work. (The positions are labeled TMS, TDO, TDI, TCK and S_TDI.) Do you have these jumpers populated?
imtiaz
Postby imtiaz » Fri Mar 17, 2017 10:04 pm
Yes - I had the jumpers on.
Postby Sprite » Mon Mar 20, 2017 4:49 am
Hmm. Do you have anything connected to the pins of the devboard?
sameer
Postby sameer » Thu Jun 08, 2017 1:07 am
I'm having the same issue. Nothing is connected to the board besides the shorting blocks (jumpers) at
USB 5V
JP8: TMS, TDO, TDI, TCK
JP11: RX & TX
JP14: CTS & RTS
Console output:
sameer@testWROVER: /opt/gnuarmeclipse/openocd-esp32$ ./src/openocd -s ./tcl -f ./esp32.cfg
Open On-Chip Debugger 0.10.0-dev-g1bc90a1 (2017-06-08-00:39)
none separate
Error: libusb_open() failed with LIBUSB_ERROR_NO_DEVICE
Error: unable to open ftdi device with vid 0403, pid 6010, description '*', serial '*' at bus location '*'
Please advise ...
Thanks for your time.
Postby Sprite » Thu Jun 08, 2017 8:24 am
Sounds like your user doesn't have rights to the USB device. Can you retry running that as root? If it succeeds, you should take steps using udev to make sure your user can access the FTDI chip we use.
sameer
Postby sameer » Thu Jun 08, 2017 4:15 pm
Thanks for the quick reply.
I tried the same command with sudo, but the same issue persists
sameer@testWROVER:/opt/gnuarmeclipse/openocd-esp32$ sudo ./src/openocd -s ./tcl -f ./esp32.cfg
none separate
And to make sure it's not a device connectivity issue, I used GtkTerm to make sure I can see the device output (I added a printf to the blink example project), and it worked just fine.
sameer@testWROVER:/opt/gnuarmeclipse/openocd-esp32$ gtkterm -p /dev/ttyUSB1 -s 115200
Am I missing something?
Postby Sprite » Fri Jun 09, 2017 7:47 am
Can you do a 'lsusb' and post the output here?
sameer
Postby sameer » Fri Jun 09, 2017 9:33 pm
Ok ... it took some time, but I figured it out.
I was having problems due to three distinct issues
A) I didn't realize that OpenOCD needed the D2XX FTDI API
B) D2XX as a user-space API conflicts with the kernel-space driver that my Linux OS automatically loads upon connecting the WROVER-KIT, so I had to follow the instructions given in this readme by FTDI regarding unloading the driver. Specifically:
If "ftdi_sio" is listed:
        Unload it (and its helper module, usbserial), as follows.
        sudo rmmod ftdi_sio
        sudo rmmod usbserial
I had to unload those two drivers every time I connected the WROVER-KIT.
C) I am using an LXC container, which did not have access to the device (it only had access to the serial files ttyUSB0 and ttyUSB1, which is why I was able to use GtkTerm with no issues). I used this guide to fix this problem.
Users browsing this forum: trendictionbot and 1 guest
