ESP32 WROVER DOWNLOAD TOOL ERROR
Salakhov
Postby Salakhov » Fri Feb 14, 2020 3:52 pm
I am trying to burn firmware to new wrover module.
Starting it is showing
AP: 30AEA4C56741 STA: 30AEA4C56740
BT: 30AEA4C56742 ETHERNET: 30AEA4C56743
But after downloading is stopping (no green line) and ERROR.
test offset : 4096 0x1000
case ok
test offset : 32768 0x8000
case ok
test offset : 65536 0x10000
case ok
CONNECT BAUD: 115200
...Efuse CONSOLE_DEBUG_DISABLE is already burned.
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
[2020-02-14 19:40:03,206][ESP8266Loader_spi[1]][espDownloader.py][line:477][ERROR]: ESP32 Chip flash download error esp_write_flash.
Where is problem?
Thanks.
Kamran
Re: ESP32 WROVER DOWNLOAD TOOL ERROR
Postby Kamran » Fri Nov 13, 2020 7:31 pm
I am also facing the same issue. Have you got any solution?
Users browsing this forum: meta-externalagent and 1 guest
