hi
What is Use of following IO pins? can they be used for normal GPIO operation?
SD0
SD1
SD2
SD3
CMD
CLK
SENSOR_VP
SENSOR_VN
I wish to know can these pins act as normal gpio? how can I use esp-idf 4.0 to configure these pin to act as GPIO?
In my project i used all the other GPIOs, and these are the only pin left and unconnected, can use any of these to drive LED
thanks & Regards
kesav
what is use of SD0-3 io pins on esp32 ?
Re: what is use of SD0-3 io pins on esp32 ?
These also have a GPIO number, so technically you can address them like any other GPIO. However, note that normally, these pins are connected to the internal flash of the module/chip/devboard you have; in that case, reconfiguring them as a GPIO will likely crash your program. Check the datasheet of whatever you're using for more info. (Note that with recent ESP-IDF versions, you can actually also use some of these pins as a SPI master bus, but that's somewhat advanced and not always good to do.)
Hi SpriteThese also have a GPIO number, so technically you can address them like any other GPIO. However, note that normally, these pins are connected to the internal flash of the module/chip/devboard you have; in that case, reconfiguring them as a GPIO will likely crash your program. Check the datasheet of whatever you're using for more info. (Note that with recent ESP-IDF versions, you can actually also use some of these pins as a SPI master bus, but that's somewhat advanced and not always good to do.)
Thanks for reply and your valuable time,
SO these pins are non usable, i don't want to crash code, can I use either of
SENSOR_VP
SENSOR_VN
pin for GPIO functioning to drive LED?
are these 2 pins dedicated or can be usedas normal gpio also?
when we use ethernet most of the GPIO are taken up, I feel ESP should introduce IC with more GPIO like 64 pin package or 48 pin package so the consumer can pick depending on needs.
Hello ht_main1
SENSOR_VP and SENSOR_VN are inputs only. So no, they cannot be used to drive an LED.
Please see Pin Definition here: https://www.espressif.com/sites/default ... eet_en.pdf
Felix
Felix
Users browsing this forum: YisouSpider and 4 guests
